  • August 18, 2022, 02:04:55 PM
Author Topic: SUGGESTIONS  (Read 14556 times)
f1int7
SUGGESTIONS
« Reply #10 on: August 09, 2001, 03:55:00 AM »
got milk?
Antacus
SUGGESTIONS
« Reply #11 on: August 09, 2001, 08:10:00 AM »
Few things I will suggest (but you have to make the final call since it is your cash)
1) read. read. read. (ok, thats really 3 suggestions in one). Start with places like http://www.tomshardware.com and read reviews, look at pics of what others have done for ideas on cooling and mods.
2) Personally I like AMD. Intel blows and Only way I would take one is if it was free (eg. system at work).
3) Case: always think about tempature and cooling. The bigger the case the more room there is for cooling. The Lian Li cases are top notch, never heard a single complaint from anyone, they also cost a lot. Stick with metal cases, avoid the plastic crap like Dell and Compaq use on some systems. screw the hydraulic cases, I have read toooo many ppl having problems with them. Looks nice - works bad
4) mobo: I have had nothing but good luck with the IWill kk266. Somebody will say it sucks, but then I hate Asus due to past Asus mobo's I have had. Read reviews, visit http://www1.amd.com/athlon/mbl and find AMD approved mobo, compare them to what different reviews say.
5) Stick with IDE. SCSI rocks but is high $$ and runs hot. Also, if you don't have any exp then SCSI is a lil harder to setup.
What I am building:
Antec SX1030
Enermax 431W Whisper psu (using the 300w Antec psu for cooling only)
IWill KK266 (avoided the -R option)
AMD 1.333ghz
GlobalWinFOP38 hsf (saving my pennies for the Swiftech MC462)
1gb ram @ 7.5ns CL2
16x DVD
12x10x24 Plextor burner
Maxtor UDMA100 Controller card
40GB UDMA100 Segate
40GB UDMA100 Quantom
SBLive Orginal 2 slot card
3Com 10/100 busmaster PCI server NIC
DigitalDoc5
It is a live and learn deal. Maybe buy the cheapest case you can find (no psu) and jsut hack it up for practice. Ask questions as you have them. I bet that you get answers, this forum seems pretty good and has a lot of activity so far :)
Hooligan
    • http://www.pclamer.com
SUGGESTIONS
« Reply #12 on: August 09, 2001, 01:35:00 PM »
I suggest you get a friend to help you.
There's only so much a website guide and a few pictures can do.
There's stuff that you WILL need help with. So call a buddy and have him help you out.
<html>http://www.stampsofmexico.org/sig.gif"></html>
PIMPY_BOY_69
SUGGESTIONS
« Reply #13 on: August 09, 2001, 03:54:00 PM »
well i found someone on ic and he helps people plan out comps and hes helping me out, i decided i'm gonna use this case ---> http://www.big008.com/ProPage.asp?ProID=PI160197
and i also decided to use the new kg7 chipset coming out, also use a raid system for the drive, gonna get the gf2 64mb pro as vid card and a plain ol soundblaster audio card, you guys got any suggestions for anything else??
Antacus
SUGGESTIONS
« Reply #14 on: August 09, 2001, 04:22:00 PM »
Thats the case I got, but the standard beige color. I have bought from big008 in the past. Was no problems with them. Don't wimp on the vid card or sound card. Make sure the vid card cooks (DDR, 6.5ns). Stick with the SBLive X-Gamer as a minimum.
Also, that case only has a 300w psu. If you plan any HEAVY mods you may want to think about a beefier psu.
PIMPY_BOY_69
SUGGESTIONS
« Reply #15 on: August 09, 2001, 06:16:00 PM »
well i plan to use the 300w for fans and accessories, and i plan to buy an additional 420 later on, when i plan on doing the mods... but i have currently an ausome sound card so i'm just gonna swap them because i use it more then anyone else, and.... no one will notice....
Antacus
SUGGESTIONS
« Reply #16 on: August 09, 2001, 06:30:00 PM »
Sounds like me with my old SoundBlaster Live. I have the orginial 2 slot card. The Plat replaced this card. Only diff is I don't have the pretty display and all my plug ports are on a daughterboard in the back instead of the pretty display up front. Someday I may actually make a case mod to move all of those up front.
PIMPY_BOY_69
SUGGESTIONS
« Reply #17 on: August 10, 2001, 12:44:00 AM »
man i wanna talk to you people live as in a chat, do you guys have an irc channel??
if not you should really get one
SUGGESTIONS
« Reply #18 on: August 10, 2001, 12:45:00 AM »
irc.atomicrhino.com  #gideontech
funny we still use the IRC rom from our old host... :D
PIMPY_BOY_69
SUGGESTIONS
« Reply #19 on: August 10, 2001, 02:36:00 AM »
i wanna use the AMD 266 KG7 1.4 chip, but since it doesn't come out for another week or so, i don't know much about it, but i don't know where i can find a quote for it... you guys know anything about it?
Page created in 0.125 seconds with 34 queries.
