  • August 16, 2022, 11:25:49 PM
Author Topic: BD133, poor overclocker?  (Read 8177 times)
« on: August 05, 2001, 06:51:00 PM »
Ok, I'm testing the Iwill BD133 motherbaord with my celeron 600...  this is my replacemnt board since my abit be6-2 bit the dust.  I'm having a problem with overclocking...  The BD133 is running an i815ep chipset...
My problem is that in my be6-2 I had my celeron 600 running at 900 (100 fsb) @ 1.8volts completly stable.  But on this board it doesn't post at a 100 fsb, and speratically at 84-87, anything higher than 87 and no post.  and those FSB are at 1.85v.  I know that this chip can do more!
I know heat isn't an issue cause I'm using it with my peltier setup, so the cpu is around -10 to 3C while it boots up until it can get into windows and warm up to around 16-20C.
Anyone know of possable problems with my set up?
Setup:
celeron2 600 (can do 900 @ 1.8 volts)
Iwill BD133 (there isn't a newer bios*)
384 megs of pc-133
geforce2 GTS 64 meg (functions fine with an agp bus of 115 Mhz, not the problem)
maxter 40 gig ata 100
10/100 pci nic, works fine with high pci buses
Onboard sound.
*correction, their wasn't a newer bios update for the motherboard, it came with the most resent one installed.
_________________
Tbird 1.4 @1.53
512 Megs PC166
Geforce2 GTS 64 Meg
Onboard Sound w00t!
16X DVD
mile_high
« Reply #1 on: August 05, 2001, 08:13:00 PM »
yea i had same problem with a new soyo mobo i bought for my celly 566.  would run 935 like a champ on and older matsonic/chaintech mobo but wouldnt go over 850 with the new soyo mobo... so i sold the soyo to my sister and we r both happy  :)
« Reply #2 on: August 05, 2001, 08:54:00 PM »
I think its only a problem with celerons too, cause other reviews have been able to oc thier p3s realy well with this board...
Page created in 0.333 seconds with 34 queries.
