  • August 16, 2022, 11:54:33 PM
Author Topic: iwill kk266-r sensors  (Read 9056 times)
jargon
« Reply #10 on: August 10, 2001, 11:59:00 PM »
ok i just overclocked it to 1512 mhz and MBM 5 reports my processor to be running at 46 degrees when it is idling. is this ok?
Antacus
« Reply #11 on: August 12, 2001, 11:13:00 AM »
Like I said, Keep it below 52C and you should be good to go. The lower the temp the better, just use 52C as a MAX.
« Reply #12 on: August 12, 2001, 02:39:00 PM »
but its not like if you temps go above 52C your going to screw things up, its just thats a good number to keep under.
jargon
« Reply #13 on: August 12, 2001, 05:39:00 PM »
i  just got another problem trying to get my temps down, read here:
http://forums.gideontech.com/viewtopic.php?topic=133&forum=5
Page created in 0.338 seconds with 35 queries.
