  • May 27, 2022, 06:59:53 AM
Author Topic: Card reader hangs boot SOMETIMES  (Read 4758 times)
« on: June 22, 2009, 10:23:03 PM »
So I recently updated the BIOS on my Gigabyte MA790X-UD4 to F3.
Then my system stopped booting.  It would boot under the following conditions:
* If you put a card in the internal USB card reader.   :wtf:
* If you had tried to boot once, and told it to try again from the "Windows failed to boot" screen.  :wtf: :wtf:
Otherwise, it tends to hang on an early frame of the Vista boot screen -- when you can just barely read "(C) Microsoft Corporation" and before the little bar displays.
I figured "maybe the card reader is finally kaput", knowing it was unreliable from day 1.  Without the reader, all is well.
So I blew 15 bucks on a new one.  Same problem.  Evidently, it's not finicky what card you use-- a 96M CF card or a 2G MicroSD or a 128M SD all work.
Anyone ever seen such behaviour?
chase!
  • The Internet!
Re: Card reader hangs boot SOMETIMES
« Reply #1 on: June 22, 2009, 11:56:45 PM »
Is it high on your boot priority for some reason?
« Reply #2 on: June 23, 2009, 12:08:08 AM »
No, it's not even on there to my knowledge (I think it's hard disc-CD-LS120)
The thing is, it makes the handoff to Vista, because we can see the Microsoft copyright line.  Even when it works, it's prone to a 1 or 2 second stall at that point now.
But  it never happened prior to updated BIOS.
« Reply #3 on: June 23, 2009, 07:04:31 AM »
Then flash back to the older BIOS if you can.
« Reply #4 on: June 23, 2009, 08:49:38 PM »
Well, on the older BIOS, it did the same thing.
It dawns on me:
1)  Have I ever booted the system without a card in the reader?  Probably.
2)  Perhaps it's a Vista thing-- since it does successfully transfer control, maybe it's barfing about "Hey, I expect a card there and it's not".
Next step:  Reinstall
Followup step:  Live with my old 96M CF card stuck in forever.
Edit:  Reinstall, same problem.
However, what I learned is that it's not a hard freeze, it's rather a stall-out.  If you spend a minute or two waiting, it picks up and boots normally.  Still, it's dramatic and wrong.
« Last Edit: June 23, 2009, 11:26:32 PM by Hak Foo »
Page created in 0.151 seconds with 33 queries.
