  • August 13, 2022, 07:47:04 PM
Author Topic: Looking for laptop tv tuner card  (Read 5104 times)
Kumi
  • Mini trucking fanatic
    • http://flatvidz.tripod.com
« on: November 03, 2008, 01:30:07 PM »
I'm looking for a tv tuner card for my laptop but i'm having trouble finding the right one. I've got a 1.80ghz amd processor with 1gb of ram and i'm looking for an internal card (Not usb unless i have to) that works with broadcast tv (Digital though since the stations are stopping analog signals) and has an fm tuner. I would like something with a small built in antenna if possible so i can pick up signals without having to carry around an antenna with my laptop. I'd also like something that isn't bulky and stands out .
I'm looking around newegg and bestbuy right now. Anybody have suggestions?
Re: Looking for laptop tv tuner card
« Reply #1 on: November 03, 2008, 08:53:51 PM »
i'm not really sure what interface you are looking for if its not usb...
YucA
« Reply #2 on: November 03, 2008, 10:29:34 PM »
might find it here, but urgannagru has a point....
http://www.geeks.com/products_sc.asp?cat=870
Kumi
« Reply #3 on: November 05, 2008, 12:59:23 PM »
I think it's called pci express or something? It's like a card that slides into your laptop. There is a empty space on the side that's filled with a plastic piece that you just pop out and slide the card in. It's like those network cards you get from verizon and stuff. If i have to get usb that's ok but i'd prefer to use that port on my laptop since i use my usb ports fairly frequent and i never use this one.
I just want something with pherhaps a small built in antenna that i can recieve fm radio signals on my laptop aswell as broadcast tv and cable/satellite. It doesn't have to be great just as long as it works properly and does that job.
I found this one but i don't know much about them except what i read. This one looks like it might work?
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100036
« Reply #4 on: November 05, 2008, 01:11:42 PM »
Looks like a good one, but it will take quite a bit for the HD processing, you might want to throw some more ram in while you are at it.
« Reply #5 on: November 05, 2008, 01:32:08 PM »
assuming that is the kind of slot you have, go for it. i believe that is a relatively new kind though.
there are express 54, express 34, pcmcia slots,and cardbus slots
bliq
« Reply #6 on: November 05, 2008, 04:18:21 PM »
that's a new express card.  not that many laptops have them yet so make sure it'll work with yours before you buy.
Page created in 0.078 seconds with 33 queries.
