  • July 02, 2022, 09:28:03 AM
Author Topic: third monitor stopped working help...  (Read 3689 times)
Soldner
« on: July 28, 2008, 10:32:11 PM »
ok so i have a three monitor set up, and im sure this the 100th time iv asked for help with this set up and yall have done a good job...anyway to the problem, for about 4 months now my comp has been running great with three monitors with the third in pci g card. even after a new install of my o/s still work...but about 3 weeks ago i moved into my roomates room across the hall and all i did is move the comp to that room. well ever since then the third monitor wont work, and when i say that i mean when i turn on my comp it post's and goes to windows startup in progress screen then after a min restarts and does this continuously... after i remove the pci card and start it with just the two main monitors it works fine...???
*iv reinserted and moved pci slots tried everything cant get all 3 up and working any ideas?
pinkpanther
Re: third monitor stopped working help...
« Reply #1 on: July 29, 2008, 12:14:43 PM »
Is it possible that the PCI card was damaged during moving?
ranukumbolo
« Reply #2 on: August 05, 2008, 11:01:44 PM »
My suggestion :
1. Try to remove or reinstall all your pci card, and then install your pci card one by one
2. The 2nd way is change your pci with new one
Page created in 0.073 seconds with 33 queries.
