  • October 20, 2020, 09:31:46 AM
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: Turning it Upsidedown(Completed)  (Read 32543 times)
AMD_Junk13
    • Ross Computer Technologies
« Reply #40 on: June 28, 2004, 09:07:26 AM »
My god that pic is 400000 Bytes larger in size of the original  :o , Please edit it
My temps are about 3-4C lower in all areas of the case. The CPU should go down more when the the themal paste settles in now it's 30-34C and was 32-36C. I'm happy with these numbers.
New specs tba...
AMD_Junk13
« Reply #41 on: July 01, 2004, 09:33:09 PM »
Small update :D
My CPU is running 4C cooler(28 Idle, 33 load) and HD and PSU are running average of 6C cooler. So as it sits the case mod not only looks good but works well. I may add upper cooling later but for now removing the last slot cover works well at removing(Venting) most of the heat from that area.
New specs tba...
schlzm
    • Schlzm's Iraq Page <ded>
« Reply #42 on: July 02, 2004, 12:36:10 PM »
You could get a card slot cooler and put it in the "top" slot to blow air out. THey run about $15 at CompUSA.
Schlzm
RaDragon
  • Tee hee hee.
    • RaDragon.com
« Reply #43 on: July 02, 2004, 12:48:48 PM »
Very nice work! I like how you made the case to fit your own needs -- definitely a true modder :D
Eventually, you may want to paint the internal chassis? Or maybe add a contrasting color for accent? :)
jpantoga
« Reply #44 on: July 02, 2004, 02:27:29 PM »
That is sooo hot!
Burst42
« Reply #45 on: July 08, 2004, 04:53:02 AM »
Modder motto: 'If you don't know what to do to it, rearrange everything...'
Well done!!!
I sense much NT in you.
NT leads to Blue Screen.
Blue Screen leads to downtime.
Downtime leads to suffering.
NT is the path to the darkside.
AMD_Junk13
« Reply #46 on: July 23, 2004, 11:18:10 AM »
I'm happy to  say my case ended up on GT's main site. Thank you Gid and to the rest of the forum for their support.
http://forums.gideontech.com/viewtopic.php?t=25480
New specs tba...
Geet Lord
« Reply #47 on: July 23, 2004, 07:47:46 PM »
I havent been on this forum much in a few months so I missed this mod.  I am very impressed by it, and really like the way you rearranged the internal components there.
danwatt
« Reply #48 on: July 23, 2004, 11:49:49 PM »
i'm almost finished with my upside-down rig. it looks exactly the same, but really messy because i just did it to see how it would come out.
Another quality post^^^
Pages: 1 ... 3 4 [5]   Go Up
