  • October 26, 2020, 04:23:01 PM
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Turning it Upsidedown(Completed)  (Read 32705 times)
AMD_Junk13
    • Ross Computer Technologies
« on: June 21, 2004, 02:29:38 PM »
This all started because I liked the design of the new LIAN-LI cases but not the outside of them. So I thought why not take my Xaser II that I like very much and just redesign it.
The start all striped down.
After some rivet drilling the parts lined up.
Removing drive cage mounts and test fitting the top on the bottom.
Some times little pieces must go to make it work... this was one of them.
Test fitting of the MB and frame work. A bit tight on the drives but a good fit. And no the cross braces are not mounted yet, that's why they are just hanging there.
Just a back shot to show how it will all lay out. I'm very happy so far with how it's working out.
This will be the new drive cage I'm using for my HD's. It is out of a gateway. The locking buttons will be dyed and the metal painted.
This is a pic of the heat shield I will install between the HD/PSU section and the MB. I cut it off the same case I got the cage.
This is a shot just to give you an idea of placement of the shield. The holes will be patched and it will be painted. for cooling of this section a intake fan will be places in the front before the HD and the 2 fan PSU will carry any hot air out the back. Before it's asked... yes the HD cage is going on the bottom.
I cut out the front section so I can make a clean install of a 120mm fan.
This is the cut out for the fan mount.
The next few pic of my great dremel skills.
These are 2 shots of the mounting plate installed and the fans in place.
Here is where I stand now the heat shield is in place and the drive cage is painted
More pics soon :D
New specs tba...
Syberz
« Reply #1 on: June 21, 2004, 02:31:16 PM »
Can't wait to see how this will end up. Keep us updated.
monkey_sass
« Reply #2 on: June 21, 2004, 02:32:38 PM »
nice idea--keep us updated.
++?????++ Out of Cheese Error. Redo From Start.  -- (Terry Pratchett, Interesting Times)
« Reply #3 on: June 21, 2004, 02:33:26 PM »
haha, that's awesome ;)
AMD_Junk13
« Reply #4 on: June 21, 2004, 02:54:03 PM »
Thanks for the good replies more updates soon.
New specs tba...
BuSkillS
« Reply #5 on: June 21, 2004, 03:02:15 PM »
wooh, thats not the right way....  to me that looks like the new btx standard, with the cae door opening on the right.  nice idea.
« Reply #6 on: June 21, 2004, 03:19:55 PM »
awesome. Can't wait to see how it turns out :thumbsup:
Loki Xtra
« Reply #7 on: June 21, 2004, 03:35:56 PM »
Nice work dude.  Gotta be one of the niftiest things I've seen done with one of those cases.
Nobody likes you. -Scott
danwatt
« Reply #8 on: June 21, 2004, 03:45:57 PM »
i just saw those lian li cases the other day. god they look awesome, but it's not too hard to guess where they got the idea from. anyways, it's looking good. save yourself two hundred bucks, and keep posting the pictures.
Another quality post^^^
prophecy421
« Reply #9 on: June 21, 2004, 04:24:44 PM »
Very nice   :D
Modding since 1992
Pages: [1] 2 3 ... 5   Go Up
Page created in 0.094 seconds with 33 queries.
