  • May 27, 2022, 08:27:19 AM
Author Topic: Computer does not boot  (Read 504 times)
Plazmik_Knite
« on: May 15, 2003, 04:00:21 PM »
I recently put my old computer back together and I find that the BIOS does not detect the keyboard, mouse, or harddrives. It does not even detect the cd-rom drive. What should I do? I think maybe it's a problem with my wiring, but I'm not sure. Any help? :idiot:
King Kong Aint Got sh*t On Me
Pudgygiant
« Reply #1 on: May 15, 2003, 05:16:56 PM »
Make sure they're all plugged in to the right places, jumper settings on CD drive are right.
K101
« Reply #2 on: May 15, 2003, 05:23:06 PM »
Heh, I just did a transfer in my system, take a look at the manuals and make sure stuff is hooked up right, and check for screws, thats what messed me up.  Luckily nothing burnt out heh :D
Morphiuž
    • http://www.GnomeLAN.com
« Reply #3 on: May 15, 2003, 09:21:23 PM »
Make sure everything is plugged in properly first.  Make sure you don't have your IDE cables in backwards.  Make sure you don't have any screws or other conductive objects laying on or underneath the board.  Clear your CMOS.  And if none of that fixes it try flashing the BIOS.
mozingod
« Reply #4 on: May 15, 2003, 09:26:40 PM »
Try reseting the BIOS... something may be corrupt.
Page created in 0.055 seconds with 33 queries.
