  • October 04, 2022, 10:52:16 AM
Author Topic: View Sonic  (Read 619 times)
iIxDaViExIi
View Sonic
« on: May 14, 2003, 11:03:23 PM »
well i been lookin at   moniters all day. and my eye has been on VIEW SONIC brands. but im having trouble on deciding on what is good and what isnt. i mean VIEW SONIC is a good brand. i jus dont kno between the E series G series A series and etc. besidings one is being better, which one  should i go for. like i was lookin at the E70FB and it end up having either MPR-II and OSD Lock at different prices too... so what is da difference and what do you recommand from VIEW SONIC.... i what a Perfect Flat screen doe... not a LCD
Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep
bbarker21
View Sonic
« Reply #1 on: May 14, 2003, 11:12:04 PM »
if you go to www.viewsonic.com it compares the different models.  i have a p model and i highly reccomend them over the others.  mine seems to have better quality versus a g model we also have.
Loki Xtra
View Sonic
« Reply #2 on: May 15, 2003, 12:03:21 AM »
My A90f+ has change the way I look at things......
19" Flat.......solid.....bueatiful picture.....
Nobody likes you. -Scott
Loki Xtra
View Sonic
« Reply #3 on: May 15, 2003, 12:04:00 AM »
Compared to my 19" Dell, the ViewSonic is god.
EDIT: Sry bout the double post......back button accident I think :P
Fuzzman
View Sonic
« Reply #4 on: May 15, 2003, 12:19:40 AM »
My ViewSonic PF790 has been great.  It took a little bit to get used to not looking at a curved screen (imagine that).  The picture is sharp and clear and at 19", gaming is better than before.
iIxDaViExIi
View Sonic
« Reply #5 on: May 15, 2003, 10:21:36 AM »
well ok i broke it down to there three screens.... i jus need help on deciding it....
PS775 - E70FB - A70
whcih one would ya consider.....
SteveyG
View Sonic
« Reply #6 on: May 15, 2003, 10:38:12 AM »
Definitely the PF775.
All of the Pro Series are excellent and use aperture grills screens. They have very good refresh rates on the pro series too.
***ArxOn***
    • http://members.cardomain.com/arxon3
View Sonic
« Reply #7 on: May 16, 2003, 03:41:09 AM »
I have the E70 which is ok, no probs at all so I recommend u to go for the PF775!
Page created in 0.071 seconds with 33 queries.
