  • February 18, 2020, 06:05:50 AM
Author Topic: your opinon on which cpu and gpu cooler to use  (Read 916 times)
LoneFrozenWolf
« on: January 09, 2003, 03:35:03 AM »
I was looking into upgrading my AMD XP 1800+ cooler and my Asus GeForce 4 TI4200 cooler and was wondering what opinons you guys in the forums had(being that you've made a choice like this before, and I like to see what others think about this idea)-side note I'm using all the stock settings, I'm not much into overclocking at this poing-.
 For my AMD cooler I was thinking of TermalTake's Volcano 9 and for my GeForce 4 I was thinking of ThermalTake's Geforce 4 chipset cooler .         Now I haven't purchased anything yet (have to save up for it), but I do wanna know what your guys/galls opinons are of these coolers and/or ideas for others.
thanks for your time
      LoneFrozenWolf
saint-oni
« Reply #1 on: January 09, 2003, 03:54:49 AM »
i just installed one of thoes thermaltake volcano 7's on an athlon xp2000+ earlier tonight. it worked good, sounded quiet, and was a breeze to install. im getting 1 or 2 more of them tommrow.
Mick
« Reply #2 on: January 09, 2003, 04:12:45 AM »
Try researching the Thermalright SK-7. It is an all copper socket A heatsink and has excellent performance at a reasonable price. It can use 80mm fans with its retention wires. Its clip uses all 3 notches instead of just one. Although it is harder than most to install. Most people find they have to push down hard with a screw driver. You're smart and I'm sure you can find reviews on it.
hyjacked
« Reply #3 on: January 09, 2003, 10:22:50 AM »
I have a volcano9 on my xp1600 now, it's running with the temp sensor and keeps it around 40c no load, around 48c running rc5-72 all the time. but it only ever hits around 4000rpm, if I put it on highest setting, it could probably keep it down around 40c under load, but it's too loud for my liking at that point.
Return_of_the_Pyro
« Reply #4 on: January 09, 2003, 02:33:45 PM »
water cooling
GLOOB!
Hi! I'm a signature virus. Copy me into your signature to help me spread.
willkill4food
« Reply #5 on: January 09, 2003, 06:29:39 PM »
I found that buying the 2 80MM fan PCI slot cooler helps your video card a lot. They cost about $10 and they put out about 60cfm..this helps cool the chip by giving it more air for the chip fan to use and by cooling the ram...I would suggest getting that..
-willkill
ReAX222
« Reply #6 on: January 09, 2003, 06:37:46 PM »
I only use Alpha's.  I went through the factory, dragon orb for P4 478 and finally the Alpha, and I love it.  Temps are about the same for the alpha and the Orb, but the alpha is a hellova lot quieter.  I liked it so much I already have the AMD equivilent for my new XP2400 coming in next week.
All opinions, expressed or implied, are mine.  If you do not like it or disagree, get stuffed.
Amorphus
« Reply #7 on: January 11, 2003, 06:09:27 PM »
ooo and the Geforce4 Chipset cooler comes with RAMsinks...
make sure your G4 is a Titanium series, though...
Fanny J. Crosby
« Reply #8 on: January 14, 2003, 08:27:19 PM »
well, the Volcano 9 is not really that good...
look at this...  http://www.overclockers.com/articles373/
Page created in 0.883 seconds with 33 queries.
