  • February 25, 2020, 01:40:50 AM
Author Topic: Home Depot has 217 Pc. Dremel set for 29.99  (Read 992 times)
arcsylver
« on: December 22, 2002, 05:40:15 PM »
I just went to Home Depot and found a fantastic deal on Dremel bits.
 29.99 for a 217 Peice set that has  the following:
Carrying case that doubles as storage rack.
2 Aluminum oxide grinding wheels 5/8"x 3/8" 120 grit
2 A. O. Grinding Wheel 3/8" x 1/2" 120 grit
2 A. O. Parabolic Wheel 3/8" x 3/4" 120 grit
6 A. O. Grinding wheel 3/4" x 1/8 " 220 grit
2 Silicon Carbide Grinding Wheel 25/32" x 3/16" 120 grit
2 S.C.Grinding Wheel 13/32" x 1/8" 120 grit
6 S.C. Grinding Wheel 3/4" x 1/8" 180 grit
4 Sanding Band 1/4" x 1/2" 80 grit
6 Sanding Band 1/2" x 1/2" 80 grit
1 Rubber Emery Wheel 7/8" x 5/32"
2 Diamond Cutter Cylindrical 3/16" x 3/8"
2 Diamond Cutter Cylindrical 3/32" x 3/8"3
3 Diamond CUtter Sphencal 5/64"
2 Diamond Cutter Sphencal 11/64"
2 Diamond Cutter Taper 1/8"
1 HSS CUtter 1/8" x 3/8"
5 Cut off wheel Fibre glass 1/14" 3/64"
30 Cut off Wheel Heavy Duty 15/16" x 1/32"
36 Cut off Wheel Regular 15/16" x 1/40"
28 Snading Disc 180 Grit 3/4" Diameter
20 Snading Disc 220 Grit 3/4" Diameter
20 Sanding Disc 240 Grit 3/4" Diameter
1 DIamond Wheel 7/8" DIameter
1 Wrench
1 Bristle Brush Radial 3/4" x 1- 3/4"
1 Bristle Brush Axial 1/8" x 1-3/4"
1 Stainless Steel Brush Axial 3/4" x 1-3/4"
1 S.S. Brush Radial 3/4" x 1-3/4"
1 Brass Brush Axial 1/2" x 1-3/4"
1 Flap Wheel 1-1/4" x 3/8" 80 grit
4 Felt WHeel 1/2" x 1/4"
1 Felt WHeel Pointed 3/8" x 3/4"
1 Felt Wheel  1" x 1/4"
1 Polish Compound
1 Cloth Wheel with Metal Flange 1" x 1/8" (16 Layers)
2 HSS Twist Drill Bits 1/8"
1 HSS Twist Drill Bit 3/32"
1 HSS Twist Drill Bit 1/16"
1 Sanding Shank 1/2" x 1/2"
1 Sanding Shank 1/4" x 1/2"
2 Collet Chrome Plated 1/8"
1 Collet CHrome Plated 3/32"
1 Collet CHrome PLated 1/16"
2 Mandrel for CUt-Off Wheel 1/16" Screw
1 Mandrel for CLth Wheel 3/32" Screw
1 Madrel for Felt Wheel
1 Dressing Stone for Silicon Carbide  1" x 3/8" 60 grit
  Not a bad list of Stuff for only 29.99 USD
 Sorry for the long post, had a lot of stuff to list.
RentonLovesJunks
« Reply #1 on: December 22, 2002, 05:43:51 PM »
actauly its not dremel accessories. its made by bob's company or something. but still cant go wrong for that price. i might go out and get 2 or 3 and sell 1 on **** and keep the rest.
castor jay
« Reply #2 on: December 24, 2002, 03:45:12 AM »
sounds like a good deal
Psycho Clowns
« Reply #3 on: December 25, 2002, 09:17:07 PM »
I got it for Christmas today. Pretty good. The cutoff wheels last pretty long but for some reason they reek so badly, even more that usual and the diamond cutoff wheel lost all cutting grit after the first 2 minutes. Other than that, pretty good.
Amorphus
« Reply #4 on: December 25, 2002, 10:23:07 PM »
diamond wheels losing their grit?  some glue job...
Page created in 0.079 seconds with 32 queries.
