  • August 21, 2019, 12:42:57 AM
Author Topic: What is up with auto sig.???  (Read 3066 times)
NMDante
  • Aaargh!
« on: August 07, 2001, 11:35:00 PM »
Why is it that sometimes it puts it on my posts, and sometimes it doesn't?
I have it selected on my preferences, and clicked on "Show Signature" block, but I never see it???
What gives?
Well, now it shows up?!?  Posted 2 other posts, nothing.  This is wierd!
_________________
If you can dream, try it!
P3 733 (not O/Ced) on an Asus M/B, 512MB PC133 RAM, Slot load DVD, CDRW, 60G & 30G (7200/ATA100) H/Ds, Hollywood + Decoder, SB Live!, and weakass 56k modem all jammed into a modded Lian Li PC60 case....modding continues
« Reply #1 on: August 07, 2001, 11:48:00 PM »
when you login while your doing a post, you have to select the show sig.
NMDante
  • Aaargh!
« Reply #2 on: August 08, 2001, 12:12:00 AM »
I do.  I usually login before I post anything, and I usually check for signature.  Guess it was turned off, or something.
Thanks anyway, Winter.
BTW - I see you're working your way back to 3000 again.....  :P
« Reply #3 on: August 08, 2001, 12:22:00 AM »
I guess so, I'm not trying that hard either :/
Page created in 0.056 seconds with 20 queries.
