  • June 24, 2019, 02:24:25 PM
Author Topic: 120mm clear fan in Canada?  (Read 701 times)
simsicle
« on: December 12, 2002, 08:46:36 PM »
Anyone know where I could find online a 120mm with clear blades in Canada? I know Ultra-Cool makes some, as seen http://www.sidewindercomputers.com/12clearulfan.html" target="_blank">here and http://www.frozencpu.com/cgi-bin/frozencpu/fan-16.html" target="_blank">here. Actually an Enermax with blue casing such as http://www.frozencpu.com/cgi-bin/frozencpu/fan-33.html" target="_blank">this one would satisfy me as well (I believe they're manufactured by Ultra-Cool too). Just as long as it's not thermally controlled, since it's for a future rheobus project. I always try to buy local (well, local being Canada-wide) if I can. Stupid customs brokerage fees.
Thanks guys!
DSLaBuda
    • http://www.modasylum.com
« Reply #1 on: December 13, 2002, 12:01:14 PM »
actually there was a clear case company located in canada that had an option on the ordering page to get 120mm clear fans and the holes cut in your case for them.
i posted a thread awhile back asking if anyone knew if you get them by themselves without the case, but noone knew.
my email to the company went unanswered.
the fans they had both clears blades and houseing, not just the blades as shown in your links.
i will see if i can find it.
---edit---
found it.
http://www.clearpc.ca/samples.html    (i believe the .ca is canada, correct me if i'm wrong)
the clear 120mm fans are $12 each (usd)
looks like a std molex connector, i don't think it supports rpm monitoring.  they also do not list the noise or airflow specs. :(
hope this helps.
---edit---
simsicle
« Reply #2 on: December 13, 2002, 10:41:42 PM »
Thanks, I appreciate. Although today, I decided to go shopping (in an electronics store, of course) and I brought back home a 120mm plain black fan with bare wires ($8), two 120mm chrome fan grills ($1.50 each) and a couple pre-wired 3pin female connectors I found in a box labeled 'Misc.' to connect to the bare wires and into my future rheobus ($0.15 each). And those prices are all Canadian. Didn't think it'd be that cheap. Anways, I figured I could always replace the fan later. Now I can start working on that intake fan mod of mine :)
Page created in 0.103 seconds with 19 queries.
