  • August 13, 2020, 01:06:56 AM
Author Topic: 120mm fans, which has the highest CFM  (Read 1951 times)
ZeRoN
    • http://www.netmaniapc.com
« on: November 25, 2001, 02:27:00 AM »
I'm looking for a 120mm fan with the highest CFM I can possibly get, please post the ones you have seen that are the highest and where i could get them at if you know
-Z
Antacus
« Reply #1 on: November 25, 2001, 03:00:00 AM »
I think you'll find that db ln some fans can be pretty high.
For cfm look at Sunon fans
For cfm/db ballance try Panaflow fans
Any of the cooling links will get you those fans. www.inflowdirect, http://www.coolerguys.com, http://www.millisec.com, etc. I have 1 Sunon and 1 Panaflow. I'll choose the panaflow over the sunon any day. Watch out tho, there are low speed and high speed panaflow versions. The low speed is only about 70-80cfm. The hs is about 110cfm. Don't quote me on those stats :)
Parez
« Reply #2 on: November 25, 2001, 08:23:00 AM »
I got a sunon 120mm w. 120 cfm 46db.
..but if you'll be extreme you can always rip a 120mm fan from a coke machine, those are 220v (in sweden..)and completely made of some metal, weights about <1 kg  =) cfm/db id don't know but it should be enough ...
brutal
    • http://www.brutal.tk
« Reply #3 on: November 25, 2001, 11:18:00 AM »
delta makes a 120mmx38mm thats 190cfm @59db/a.
you can go to my site: http://members.home.net/b-bell/ and look under Case Fan Reference and see who makes what, finding some of the bigger models is tough tho.  uranianman found some 120mm deltas that are 152cfm @ 53db/a so talk to him if those will work
basic
« Reply #4 on: November 25, 2001, 01:12:00 PM »
i've got 2 delta 120's at 152 cfm at 53 dBA. sounds like a 38 cfm delta when i run them at 7 volts, but when they are at 12, boy will they run...
