  • June 03, 2020, 01:58:14 PM
Pages: [1] 2 3 ... 5   Go Down
Author Topic: UpDated!! FSFT : Cleaning house - newer stuff, check it out  (Read 9683 times)
mile_high
« on: November 29, 2002, 08:11:33 PM »
IWill slotket  for socket 370 fsb 66/100/133 select Vcore 1.30v 3.5v in .05 increments $10 shipped
Conner CTD8000R 4/8 gig SCSI DAT Tape Backup w/ AdvanSys 393OU PCI SCSI card 20" 2 connector rounded SCSI cable, 14 Maxell 120 meter tapes, 5 Sony 120 meter tapes, 4 TDK 90 meter tapes and 1 Maxell cleaning tape, 3 tape boxes $75 + shipping click 4 pic
Cisco 675 external DSL router, with Docs, Cables & filters  $40 shipped  click 4 pic
Arescom NetDSL 800 USB modem still in box  $17 shipped click 4 pic
Mach 2 56k PCI voice/fax/modem still in box with docs, discs $12 shipped
Fan Bus for 4 fans with an 8”molex pigtail, with double stick foam for attaching to case pics available $12 shipped  click 4 pic
Lazer LED like lites with 12” molex pigtail, in Red, White, Blue, Green, Yellow, Orange, Purple, UV, Aqua, or any combo like Red White & Blue ie the far right one in the pics, all Leds 5000mcd or higher except for Purple which is 2000mcd & UV which mcd is not applicable, double sided foam tape included $12 shipped  click 4 pic1, click 4 pic2, click 4 pic3, click 4 pic4
Sound Deadening Material, 2 pieces 8X16 & 2 pieces 14X16 for mid towers, ask about full tower $18 shipped  click for info & pics
60mm chrome or plastic fan grills $1 if bought with a  fan, $1.50 shipped
80mm chrome or plastic fan grills $1 if bought with  a fan, $1.50 shipped
92mm chrome or plastic fan grills $1 if bought with a  fan, $1.75 shipped
120mm chrome or plastic fan grills $1 if bought with a  fan, $1.75 shipped
Chrome grill click 4 pic
Black plastic grill click 4 pic
Anodized paint on grills in blue, red or gold add .50 click 4 pic
5 Brand New Delta 38 60mmX25mm fans 46dB\38cfm 6800rpm 3 pin w/ tach $5 shipped $9 for 2
7 Brand New JMC-DaTech 60mmX15mm fans 26dB\18cfm 3400rpm 3 pin  $4 shipped $7 for 2
10 Brand New JMC-DaTech 80mmX15mm fans 30dB\35cfm 3200rpm 3 pin  $5 shipped $9 for 2
2 Brand New JMC-DaTech 80mmX25mm fans 26dB\29cfm 2500rpm 2 pin  $5shipped $9 for 2
6 Brand New JMC-DaTech 80mmX25mm fans 33dB\32cfm 3200rpm 3 pin  $5 shipped $9 for 2
6 Brand New NMB  80mmX25mm fans 34dB\39cfm 3250rpm 3pin $5 each shipped, $9 for 2
16 Brand New NMB  80mmX25mm fans 36.5dB\44cfm 360rpm 3pin $5 each shipped, $9 for 2
20 Brand New NMB 92mmX25mm fans 41dB\63cfm 3800rpm 3 pin $7 shipped $12 for 2
1 Brand New Nidec 92mmX25mm fans 39.5dB\56cfm 3200rpm 3 $7 shipped
10 Brand New Delta 92mmX25mm fans 45dB\68cfm 3800rpm 3 pin  $6 shipped  $10 for 2
2  Brand New Nidec 120mmX38mm fans 41dB\89cfm 2450rpm  Molex connector  $9 shipped
3  Brand New YS-Tech 120mmX38mm fans 45dB\125cfm 2800rpm  3pin connector  $12 shipped
1 Brand new 1 used  ComAir Rotron JQ12B4 150mm/6” fans 12VDC fans with grills 54dB/235cfm 3500 rpm, still in the boxes, unwired, for $1 I will add a molex pigtail, you specify the length $18 shipped new, $14 shipped used  click 4 pic
Mini DPDT toggle switch ON/OFF/ON perfect for modding  $2 shipped 5 for $9  click 4 pic
6 Maxell HS-4/120s DAT 4mm Backup Tapes 120 meter  4gig\8gig & 1 Head Cleaning tape all brand new still in shrinkwrap $14 shipped
SymBios Logic SCSI-2 PCI Plug n Play card with NCR 538C10 chip, 50 pin internal connector and db25 pin external connector with drivers and 3 connector cable  $20 shipped
Pending USB Color PC-Eye Web Cam with drivers and Various Software programs on cd $15 shipped
10 5.25 to 3.5 drive adapter kit with rails and faceplate  $3.00 shipped click 4 pic
Brand New D-Link DFE-904 10\100 Network hub, 4 ports + 1 uplink port for stacking, with power supply brand new RMA replacement, only tested to make sure it works $15 shipped.
2 brand new Fujitsu 4700 Keyboards with AT connectors still in box $10 shipped or $17 shipped for the pair
Athlon CyberCooler  heatink/fan  3 fans new in box  $7 shipped click 4 pic
SOLD!!!  Hitachi V-209 20mhz Mini Portable Dual Channel Oscilloscope, AC\DC with battery operation with asst’d cables, probes, and a 60mhz probe built in battery charger with hard carry case. A brand new 1 costs $1025.00   $250 shipped click 4 pic/datasheet
Heathkit ET-3600 Analog Trainer - Variable regulated positive &negative 15 VDC power supplies, 200Hz to 20kHz frequency generator with sine & square wave outputs, 2 60Hz sine wave signal sources @ 15 & 30 VAC, 1000 ohm & 100k ohm potentiometers, large removable breadboard & connector blocks for solderless connections between parts and wires, built in ET 3567 Backpack connector, with manual and schematics $55 shipped  click 4 pic
Heathkit ET –3700 Digital Trainer – 3 power supplies to power both digital and linear circuits, 4 logic Data switches, 2 no bounce logic switches, 3 frequency pulse generator (clock), 4 LED logic state indicators, internal circuitry compatible with most of todays commonly used logic families, large removable breadboard & connector blocks for solderless connections between parts and wires, with manual and schematics $55 shipped  click 4 pic
Male Molex Connector w/ 12” pigtail $1.35 shipped  click 4 pic
Female Molex Connector w/ 12” pigtail $1.35 shipped
20 PC power cords $2.50 shipped, 5 for $10
50 floppy drive cables 20” $1.75 shipped 5 for $8
25 ATA33 IDE cables 24” 3 connector  $2 shipped 5 for $9
3 ATA33 IDE cables 36” 3 connector  $3.50 shipped
30 ATA66/100/133 IDE cables 18” 3 connector  $3.25
5 ATA66/100/133 IDE cables 24” 3 connector  $4.25 shipped 3 for $10
25 SCSI 50 pin cables 24” 3 connector  $3.50 shipped 3 for $10
Assorted other SCSI cables both internal and external, ask if you are interested
13 USB type A-male to A-male 6’ translucent blue $3.50 shipped click 4 pic
9 USB type A-male to B-male 6’ translucent blue for scanners, printers, hubs, modems  $3.50 shipped click 4 pic
12 USB type B-male to B-male 10’ translucent blue extension cable for cable above $5 shipped click 4 pic
9 CD-Audio digital audio cable $3 shipped click 4 pic
9 CD-Audio Universal audio cable, can connect 3 cdrom/cdrw/dvd devices to your sound card, 2 connectors for sound card side as well $4 shipped click 4 pic
2 10 ft printer cables $4 shipped
Split Loom tubing in 7 colors – black, white, red, yellow, purple, blue, teal in 3 sizes Ό is great for psu power cables, 3/8 for floppy, ide, scsi cables and ½ for the psu motherboard cable $.30 a ft. for Ό, $.40 a ft. for 3/8, $.50 a ft. for ½ click 4 pic
Cable/Zip ties in 15 colors $1.25 for 10 shipped, pic a color from the pic
13 copper AMD athlon/duron cpu shims, for older non palomino/morgan cpu’s $3 shipped click 4 pic
i have some older stuff available here
prices aren't written in stone...
heatware is mile_high(montana), eMail is mile_high@gideontech.com
Loki Xtra
« Reply #1 on: November 29, 2002, 10:30:01 PM »
d00d  You have all this lyin around?
I am interested in these tho.
19 Brand New NMB 80mm X 25mm 36.5dB\44cfm 360rpm 3pin $5 each shipped, $9 for 2
What could you do for 4 of em?
Also, -80mm chrome & plastic fan grills $1 if bought with a fan, $1.50 shipped
btw, I couldn't finish the list so I may edit for more stuff.
Nobody likes you. -Scott
Djurkinthebox
    • Challenged Mentally
« Reply #2 on: November 29, 2002, 10:36:33 PM »
Either he just got all NEW stuff, or he just got an inside tip that someone has a contract out on him.  Either way, he won't need it.  Especially if it's the latter.  :P
Loki Xtra
« Reply #3 on: November 29, 2002, 11:01:01 PM »
Seriously, Thats alot to have sittin around. Im curious as to where it is and how he got it.
Djurkinthebox
« Reply #4 on: November 29, 2002, 11:04:23 PM »
Well... he's one of the GT Moderators... so, he probably has even more stuff lying around.  I mean, they do reviews on stuff, and everything.
mile_high
« Reply #5 on: November 30, 2002, 04:44:11 AM »
well i am ancient compared to most of you  :)   been tinkering with computers for longer than a lot of u have been alive,  got my 1st computer in 83 just before i went on my last cruise in the navy...  it was a Texas Instruments dont recall the model #  and i have been collecting assorted flavors of computers ever since...  be glad i dont put my apple II stuff up on here   :D
as for where it is,  its all around me  i'll take some pics
the closet in my computer "dungeon" http://home.attbi.com/~mile_high/pics/compjunk01.jpg"target="_blank">pic01
my workbench i made http://home.attbi.com/~mile_high/pics/workbench1.jpg"target="_blank">pic02
Loki Xtra
« Reply #6 on: November 30, 2002, 07:48:43 AM »
Cool stuff man.  Very cool stuff.
btw, maybe I missed it on the list, but do you have a power supply layen around too? Maybe even a case?
mile_high
« Reply #7 on: November 30, 2002, 01:54:22 PM »
Loki...
mmm i kow i have like 3 - 4 at power supplies...  the new case i bought didnt come with a psu cuz i was gonna use one i have in it.. let me see if i have a spare atx psu assuming thats what u want  u have a pm as well
« Reply #8 on: November 30, 2002, 06:07:42 PM »
That Visual Studio 97 is a good buy.  I would get it if I didn't have one already.  Do you have anything with VB6?
Mick
« Reply #9 on: November 30, 2002, 06:42:34 PM »
Do you have a site with everything listed to buy like on ****, half.com, yahoo shops, amazon, etc. I'm interested but its hard to see what is available since you can't update this list all the time.
Pages: [1] 2 3 ... 5   Go Up
Page created in 0.085 seconds with 33 queries.
