  • February 18, 2020, 06:10:45 AM
Author Topic: your opinion please  (Read 678 times)
Sergio_79
your opinion please
« on: November 28, 2002, 02:31:22 PM »
i have my system oc by increasing the fsb from 133 to 15 (ok not too much oc but just starting) howver this increases my temp quite a bit !! whilst watercooling project starts will u suggest me to put fsb in default whislt surffing or working (word proccessing) and then increase it when playing or compressing or converting divx?
thanks
hyjacked
your opinion please
« Reply #1 on: November 28, 2002, 02:50:40 PM »
what are your computer specs?
in most cases, you won't really see the increase in performance with increasing by 2. sure you might get the extra couple points on the 3dmark test or other benchmarks,, maybe a frame or 2 on games, is it really needed though. I'd say run your computer at whatever is stable, and fast enough for you, when it's not, start upping it till your computer is no longer stable, than back down a few so your stable again. once this becomes to slow for you, upgrading would be your option.
strongShock
    • http://www.strongshock.com
your opinion please
« Reply #2 on: November 29, 2002, 05:24:43 PM »
so you're planning an h2o system? i'd leave the OC alone until you get the h2o up & running, unless you need framerates while you're gaming. game framerates are what OCing is all about anyways.
Page created in 0.062 seconds with 33 queries.
