  • August 13, 2020, 12:26:26 AM
Author Topic: 1600+ overclocks OWN 1? POST IT!  (Read 1955 times)
willkill4food
« Reply #10 on: November 21, 2002, 01:35:48 PM »
I bought the 1 year warrenty for $5
-willkill
The Fake
« Reply #11 on: November 22, 2002, 04:10:12 AM »
I'm running my AGOIA XP1900 @ 2100.
Globalwin 80mm fan heatsink
3* 80mm fans around the case
1*90 mm blowhole on the bottom of the case (i have quite big feet)
1*90mm exhaust on the top
1* 120 front blowhole
HDD Cooler
ORB on GF4
extra chipset coolers (2*30-1*60mm fans)for my MSIKT3 RAID Ultra
And a very smart airflow if you ask me. My case is 100% dustless though, i got filters all around the blowholes and the way it is set-up any dust thats there is in the case is getting lifted up by front and bottom fans and then thrown out of the top exhaust fan.
Soon i'm thinkning of going even further with WC. I think i should get  around 2500 out of it.Maybe more...
mobuis
    • http://www.mobuismodule.tk
« Reply #12 on: November 23, 2002, 04:52:39 AM »
i didn't know that covered roasting or else i would have bought it:'(
Sergio_79
« Reply #13 on: November 24, 2002, 10:13:34 AM »
FSB=150
multiplier = 10.5
so 1575 MHz out of my 1600xp
core V= 1.76(default)
temperatures:
at idle:46C
at load: 50C
How can i reduce my temp to increase my fsb? i went mad with so many fans and i just have my computer without the side panel.  any ideas ?
thanks
mobuis
« Reply #14 on: November 24, 2002, 09:53:32 PM »
try a better heatsink... or if you really are serious about OCing do what i did and watercool w/ a pelt or just watercool
Chavezxp
« Reply #15 on: November 27, 2002, 03:53:09 PM »
I got my 2000+ to 1666Mhz oh wait thats defalt  :rotflmao: sorry
daymar
« Reply #16 on: December 05, 2002, 11:10:53 PM »
Currently running my 1600+ @ 1900+
FSB: 153
Multiplier: 10.5 (still locked..)
Voltage: 2.0v (motherboard supported)
Idle: 98F
Full: 105F
Heatsink: SLK-800 /w 80mm Sunnon fan (~32cfm i think)
Just installed the processor and some new ram today and have been running D2OL for about 2 hours..  I may unlock it later on since I'm pretty much maxing out on FSB but I know the processor can go further, only reason it's not higher is because the onboard sound doesn't want to work at anything over 155 or so..
Sergio_79
« Reply #17 on: December 06, 2002, 04:49:30 AM »
yesss i found the limit !! yesterday i run my processor athlon1600+ at 157 fsb everything perfect but after 10 min of hard benchmarking the sysetm rebooted (winxp) i tried it several time and keep doing it.
157 fsb with locked multiplier at 10.5 ==> from 1400 to 1647 !!!! :o
maybe i need to cool it down a bit so it does not reboot.
what do u thing will this allow me higher fsb?
temp: idle 47
load: 53 (but with lower fsb i have had them higher :-?  :-?
rt3d
    • http://home.earthlink.net/~jasonjessup
Serg
« Reply #18 on: December 06, 2002, 11:36:34 AM »
Increase your voltage and decrease your temperature, Spain Sergio.
Im running my 1600 at about 1.7g with a KT4 Ultra at 1.8*V.
daymar
« Reply #19 on: December 06, 2002, 06:23:33 PM »
Sergio_79 - I agree with rt3d, increasing voltage will probably fix the rebooting problem.  Really thinking about unlocking my current processor cause at the temps I'm getting I'm positive it can go faster.. just not sure what my max multiplier will be..
Page created in 0.07 seconds with 33 queries.
