  • September 16, 2019, 03:14:28 PM
Author Topic: 1600+ overclocks OWN 1? POST IT!  (Read 1809 times)
mobuis
    • http://www.mobuismodule.tk
« on: November 15, 2002, 05:51:00 PM »
hey all you people with 1600+'s post what you overclocked to and like what FSB, multiplier, if you did vmod, and what kind of cooling. Also does anyone know a easy way to put a resistor onto the motherboard for a voltage mod cuz i suck at soldering and i tried it before and i almost screwed over my motherboard(i had to unsolder a bunch of crap:-/). I heard something about some clips or something im not sure what they were please replay:-)
MR.G
« Reply #1 on: November 15, 2002, 10:20:00 PM »
my xp1600 is overclocked to an xp 1900
        fsb-153
multiplier-10.5
Thermaltake volcano 9 cpu cooler
ozntz
« Reply #2 on: November 16, 2002, 09:44:00 AM »
check here for some other peoples speeds
http://www.cpudatabase.com/
willkill4food
« Reply #3 on: November 17, 2002, 10:32:00 AM »
my XP 1600 OCed to a 2300/2400
FSB - 350
multiplier - 10.5
1.84 ghz
-willkill
Sergio_79
« Reply #4 on: November 17, 2002, 10:41:00 AM »
what temperatures are you getting with those OC systems? how did you overclock them?
strongShock
    • http://www.strongshock.com
« Reply #5 on: November 17, 2002, 10:45:00 AM »
OMG willkill, with what cooling, mobo, & RAM?
mobuis
« Reply #6 on: November 17, 2002, 02:45:00 PM »
FSB - 350
multiplier - 10.5
1.84 ghz
-willkill
at what voltage??
mobuis
« Reply #7 on: November 19, 2002, 05:35:54 AM »
bump
willkill4food
« Reply #8 on: November 19, 2002, 03:45:15 PM »
I am using a thermalright AX-7 with a 80-120mm adapter with 120mm 80cfm fan..this is the best HSF you can buy with the lowest dba and the highest cfm
I am running at 1.8v but i had some power problems at a LAN party, and now my chip is roasted, it was a AROIA0213 which means it is the best possible chip you can get for OCing..hopefully I will get one just as good when i send it back to newegg.com
-willkill
mobuis
« Reply #9 on: November 20, 2002, 02:05:18 PM »
you can send them back if there roasted?
Page created in 0.513 seconds with 19 queries.
