  • October 23, 2021, 01:04:32 PM
Author Topic: Water Cooling Kit...  (Read 7936 times)
TitoJackson
« Reply #10 on: August 10, 2001, 07:05:00 PM »
Adam, you have some choices before you start burning dough on cooling.  First you should ask yourself if you want to use a radiator,  If you don't use a radiator, you need a large volume of water in a fish tank or  something.  That is how Nuclear reactors cycle their water.  After that I would look at finding individual components for your customized kit.  Try and get all aluminum or all copper else you'll have a redox reaction happening in your cooling rig(BAD).  Don't buy a kit because they charge you for all the individual components and their tubing which is usually overpriced.  For tubing I would just go to the hardware store, and for a pump just do a little research.
ifmu
« Reply #11 on: August 23, 2001, 02:32:00 AM »
aye, I would have to agree with tito on that matter. It works best from what Ive seen and read that you can get a better setup than you can buy outright. Let alone you can say 'Hey I built this!' :P
But you can get much better by building it yourself than buying the kit...
Page created in 0.082 seconds with 34 queries.
