  • July 23, 2021, 05:44:02 PM
Author Topic: Water Cooling Kit...  (Read 7589 times)
AdamG
    • http://kinetikclone.com
« on: July 30, 2001, 11:59:00 PM »
I am a wanting to get into water cooling
Will this kit be ideal for me?
http://www.hardcorecooling.com/623.htm
Also is there anything i should know about water cooling before i give it a try :D
[ This Message was edited by: AdamG on 2001-07-31 01:00 ]
WireX
« Reply #1 on: July 31, 2001, 09:07:00 AM »
I'm not exactly an expert at watercooling but i do know a few things... thats pretty good :)
I would buy it if I had the money, and if you do buy it, hook everything up OUTSIDE the computer they way your fonna want it, and let it run for 48 or more hours, to check for leeks.
-WireX
« Reply #2 on: July 31, 2001, 01:37:00 PM »
Erm, its OK.
Personally a dangerden copper maze2 water block would be better.  I also don't like the water pump they use.  Its a Rio 120(180?), Rios are prone to failure, and aren't very good pumps, they have a low head(how high it can pump water).  You could build your own water cooling setup for about the same cost as that kit ( ok, a little more) that would be 2 times as good.
The other issue I have with this kit is that it uses an aluminium radiator and resevoir, and it has a copper water block.  when you put those in a electrolitc fluid (read water) they make a very good battery about 1 volt.  this will cause the aluminuim to corrode.
[ This Message was edited by: winterstick on 2001-07-31 14:38 ]
AdamG
« Reply #3 on: July 31, 2001, 01:42:00 PM »
ok, well im to noob to water cooling, so is there any kits you would suggest to get me started?
kid
« Reply #4 on: July 31, 2001, 01:42:00 PM »
voltage + cpu = fried well maybee if it somehow touched a vital part of you computer but other than that the copper (I believe) will begin to degrade and your aluminum radiator might get some coper deposits on it, also to clarify on the water its only electrically conductive if it has other stuff in it, ie chlorine, metals, for pure H20 isnt electrically conductive
« Reply #5 on: July 31, 2001, 03:21:00 PM »
erm any of the dangerden kits are pretty good, and they have a nice water pump to, I think they are closed loop system instead of an open loop (resevoir).
http://www.dangerden.com/mall/kits_pumps.asp
They are kinda pricy though, if its to much money the kit that you were looking at would work, but I don't really like it...  especaily the mounting mechanism, that screw in the middle has broken more cores than any other system devised!
And to clarify distiled water can still be conductive, since its the ions in the water that cause it to be conductive.
kid
« Reply #6 on: July 31, 2001, 06:19:00 PM »
this affrent winter doing some testing on a HSF found that the bolt through mobo HSF had taken 2 bites out of his core
« Reply #7 on: July 31, 2001, 06:25:00 PM »
affrent??
kid
« Reply #8 on: July 31, 2001, 06:33:00 PM »
well that was strange I swore I typed after but anyway
kid
« Reply #9 on: July 31, 2001, 06:34:00 PM »
if you need deionized and distilled water you can still do that you get distilled water and run it through a filter
Page created in 0.059 seconds with 33 queries.
