  • June 18, 2019, 04:26:48 PM
Author Topic: 120mm cpu fan. good idea or bad idea?  (Read 2206 times)
saint-oni
« on: November 03, 2002, 11:21:00 AM »
im sure weve all seen the 60mm to 80mm heatsink fan adapters, and im sure weve all seen the 80mm to 120mm adapters as well... im thinking of putting an 80mm adapter on my heatsink, adn then throwing a 120mm adapter on top of that. im guessing that itll give me some sweet temps with little or no noise. has anybody tried this before? will it work? if youve seen it done on line can you post a link?
« Reply #1 on: November 03, 2002, 12:23:00 PM »
The only thing to worry about there is the weight of the fan.  You might have your heatsink just snap off of the lugs.  I think the safe weights are 350 g or less for a one-lug clip and 500g or less for a three-lug clip.
GrendelPrime
« Reply #2 on: November 03, 2002, 08:53:00 PM »
With the 2 adapters stacked, the fan should be close enough to the side panel to be mounted there.  That would alleviate the stress on the lugs, and provide a source of fresh, cool air for the CPU.
Nice idea, need I say we want pics if you do it?  :)
outther
« Reply #3 on: November 04, 2002, 12:15:00 AM »
What Heat sink are you gonna run this 120mm on! 120mm man that will be bad a$$ cooling.
Yes pics please! 8)
Squeak
« Reply #4 on: November 04, 2002, 12:52:00 AM »
why sit at 120
y not make a hole in ure case and get a 120 to 192 adapter??/??
sweet idea though
saint-oni
« Reply #5 on: November 04, 2002, 01:12:00 AM »
i thought about mounting it inside the side window (very easy to do) but that would mean that id end up taking off my fan every time i open my case. ill probably just make a vent right next to the fan, as to the weight... has anybody ever noticed that right above where the cpu is mounted on the newer antec cases, here is a little bar that runs from side to side i think its there to strengthen the structure. if you look at it closely, there is a threaded hole that a mobo mounting screw will fit in. i have no idea why that hole is there, but im thinking of making a small support off of that. my girlfriend is hooking up her webcam soon, ill start posting pics of all these weird ideas and stuff soon.
saint-oni
« Reply #6 on: November 04, 2002, 01:39:00 AM »
i cannot find this 192mm adapter of fan that you speak of. if i could, i may well be crazy enough to try it.... care to post a link where i can get one?
Army_Of_One
« Reply #7 on: November 10, 2002, 04:17:00 AM »
There are people on other forums that have tried this, some have got good and some bad results.  Why no put a 120mm on the side panel and a normal 60 or 80 mm on the HS and duct it to the 120mm... I bet that'd do just as well if not better.  Just make a cardboard duct!
saint-oni
« Reply #8 on: November 13, 2002, 10:14:00 AM »
thats a good idea. i think ill try that.
warriorx1
    • http://warriorx.tripod.com/
« Reply #9 on: November 13, 2002, 11:01:00 AM »
a girlfriend with a web cam huh?  you lucky guy :D
(sorry, didn't have anything to add to the thread but i hadn't posted anything all day and was having withdrawls ;) )
:lol:
Page created in 0.068 seconds with 20 queries.
