  • December 04, 2021, 05:55:51 PM
Pages: 1 ... 14 15 [16] 17   Go Down
Author Topic: Guide: Vinyl Dye Tutorial and FAQ  (Read 110436 times)
~Link~
    • Project 365
Re: Guide: Vinyl Dye Tutorial and FAQ
« Reply #150 on: May 23, 2006, 11:43:38 PM »
err, Sandpaper?
1 photo per day, for 1 year.  http://checkonetwo.ca
highbomber
« Reply #151 on: May 24, 2006, 05:11:33 AM »
Stupid me. I am trying to keep the original grain of the wood and sanding is a last resort.
« Reply #152 on: May 24, 2006, 01:25:33 PM »
You want to vinyl dye wood?
Wood should be painted, plastic should be dyed.
highbomber
« Reply #153 on: May 24, 2006, 02:44:14 PM »
It is plastic. Sanding is last resort. I want to use vinyl dye but I have to take off the primer. Is there any way I can take off primer without sanding.
TBoneM91
  • I like beer
    • http://www.tonysmeat.com
« Reply #154 on: May 24, 2006, 05:20:32 PM »
the plastic is wood-grained? you could try paint thinner but I have a feeling it will melt the plastic.... and primer is sorta designed to stay put. at this point, it'd be easier to go forth with regular painting since it is primed.
|\_/|
|O,O
highbomber
« Reply #155 on: May 24, 2006, 06:08:44 PM »
Well I wil try break fluid and if it doesnt work I will go forth with regular painting.
« Last Edit: May 24, 2006, 06:35:57 PM by highbomber »
« Reply #156 on: May 24, 2006, 06:31:57 PM »
Once you go the paint route, you can't go back.  That is the first and most important rule to vinyl dye.  The primer has effectively sealed the plastic, and unless you sand back into "virgin" plastic, the dye can't penetrate and is pretty much useless.  Unfortunately, you're stuck with paint now.
highbomber
« Reply #157 on: May 24, 2006, 07:19:49 PM »
If I don't sand is it possible to take the Primer off with a solvent and then use dye. Can a strong solvent such as break fluid remove primer and restore the plastic?
« Reply #158 on: May 24, 2006, 10:56:35 PM »
Anything capable of removing the primer is also going to eat plastic.
lovol
« Reply #159 on: September 04, 2009, 04:48:49 AM »
Hi, I read your article and Vinyl Dye sounds well better than paint, it took me ages to find somewhere in the UK that will actually sell this over the web.The first place I ordered was out of stock of white, and took ages to tell me,  I ended up with some stuff made by magix from www.vinyldye.co.uk .
I canít believe I didnít know about this stuff.
Since Iíve changed my surround sound from Black to white, my friend keeps asking me if it would dye a PVC door? Do you know if it would? From maybe white (his is white) to red?
Pages: 1 ... 14 15 [16] 17   Go Up
Page created in 0.073 seconds with 33 queries.
