  • July 04, 2020, 01:18:38 PM
Author Topic: Dragon Orb 3  (Read 3862 times)
xerxus
Dragon Orb 3
« on: August 06, 2001, 03:05:00 PM »
hey, I got one of the dragon orbs and this thing is works wonders. I love it. The last heatsink I had was a Volcano II. That one sucked. my comp was running 1ghz at 138+ F. I put the dragon orb on and now I run 1.333ghz at 121F. lovely lovely lovely. I think I can maybe get it to 1.5 or higher. Just wanted say how good this thing has been to me. hehhe
Dragon Orb 3
« Reply #1 on: August 06, 2001, 03:06:00 PM »
yes, it is pretty good isn't it?
Antacus
Dragon Orb 3
« Reply #2 on: August 06, 2001, 03:11:00 PM »
nice. Just watch it. You are still runnin ~50C which is only 2C shy of what I personally would consider a safe point. Also, if you are using the mobo sensors I found them to be off, they seem to run 2-3C colder then the actual core temp.
That 121F/49.4C under full load? I had an orb style (not Dragon) that had 24cfm and my 1.333ghz ran at 58C full load. Upgraded to a GlobalWin with a Delta 38cfm fan and temp is now 51C full load (still too hot for my likes).
Dragon Orb 3
« Reply #3 on: August 07, 2001, 04:10:00 AM »
are you using that vrappy black thermal pad that came with the dragon orb, if so, take that sh*t off and get some really thermal paste, that alone will drop your temps alot.
Hooligan
    • http://www.pclamer.com
Dragon Orb 3
« Reply #4 on: August 08, 2001, 05:32:00 PM »
dragon orbs suck.
good thing for you i ugh... recycle them
:P
<html>http://www.stampsofmexico.org/sig.gif"></html>
f1int7
Dragon Orb 3
« Reply #5 on: August 09, 2001, 03:42:00 AM »
so pretty looking...
