  • November 17, 2019, 08:18:36 PM
Author Topic: I got a original Ideal. Will it work?  (Read 798 times)
XianModiFidebyHim
    • http://home.insightbb.com/~msearc/
« on: October 06, 2002, 08:31:00 AM »
OK I just bought a new Zalman CNPS-3100 Plus from directron http://store.yahoo.com/directron/cnps3100.html
Here my ideal. Isntead of mounting it how its supposed to mount (the edges of the fins horizontal and the fan in front of them) I want to mount it sideways. My ideal is that If the edges of the fins are vertical and I bend the fan mount bracket to put the fan underneath pointing up toward my power supply then my hot air would exhuast better tthrough my top blowhole. I think this new arrangement might even work better than the suggested way. But are the mounting holes around the proc. perfectly square? Will I be able to mount this cooler sideways?.  I could just look and see but then Id have to move my heatsink. Im lazy. Does anyone know?
Cave_Troll
« Reply #1 on: October 06, 2002, 08:55:00 AM »
Hmm.. I do not think it will work because of the way it mounts. But I guess you will find out when you get it. It makes sense to mount it that way, but it all depends if it can be moved to fit.
XianModiFidebyHim
« Reply #2 on: October 06, 2002, 09:03:00 AM »
Well I also bought a webcam and Ill post pics if/when I get it to work. My webcam and cooler are comming at the same time. Ive done a lot of stuff to my comp so Im excited about getting pics online. An I think Im gonna be a new regular here. I like it.
Page created in 0.048 seconds with 18 queries.
