  • March 31, 2020, 08:30:33 PM
Author Topic: ThermalTake Crystal Orb  (Read 6605 times)
myr
« Reply #10 on: October 11, 2001, 08:17:00 PM »
oh and if i try AS Epoxy, how can i get it off some time later?
bLiNdPyRo
« Reply #11 on: October 11, 2001, 08:25:00 PM »
Er... freeze the card and pry it off with a screwdriver? Not sure really, I never really used that adhesive so I don't know how strong it is.
basic
« Reply #12 on: October 12, 2001, 01:04:00 AM »
no, you use AS expoxy that thing will NEVER come off, not without damaging the chip anyway. AS Expoxy has a holding strength of like 2 tons/sq inch. Figure the average voodoo chipset to be 1.25 by 1.25 that is a holding force of 3.5 tons. of course i don't know if AS expoxy has that holding strength, but you use it don't count on getting those things apart, ever.
bLiNdPyRo
« Reply #13 on: October 12, 2001, 01:11:00 AM »
Damn. It'd suck if your fingers got epoxied. =P
basic
« Reply #14 on: October 12, 2001, 01:39:00 AM »
that's why it has a hold time of like 15 min, and if you did somehow manage to expoxy your fingers together, all that would happen is you would peel off your 1st layer of skin, which isn't bad, becuase it will grom back in 3 days anyway.
Page created in 0.059 seconds with 33 queries.
