  • December 11, 2019, 08:59:35 PM
Author Topic: Neon Lights  (Read 9085 times)
CoDe_MaStEr_JoN
Neon Lights
« on: August 05, 2001, 02:16:00 AM »
I have started to build my own computer and i bought all the lastest hardware
AMD Athlon 1200
ELSA GLADIAC 920 (Geforce 3)
Sound Blaster live platinum 5.1
ect..............
also i ordered a case window and a sound sensative liquid neon light.
The neon light looks really cool with the liquid glow and the case really shines but........ The neon light is about 15+ inches and takes up alot of space.. the only place that it would fit in my case was under the power supply and almost popping out of a drive bay....... and it is taking up 2 drive bay slots and with a cd drive and the sound blaster i have not more slots to add stuff.... i was wondering if anyone thinks it is worth to keep the neon light or just get a smaller one cuase it looks really kool and i dont know what to do
thx
Jon
Neon Lights
« Reply #1 on: August 05, 2001, 02:50:00 AM »
why can't you put it at the bottom of the case like everyone else?
Antacus
Neon Lights
« Reply #2 on: August 05, 2001, 08:01:00 AM »
Thought of trying the flexable neon lights? Wrap them around your window and fans and attach to the case via epoxy.
I am pondering over those, but they are a little high priced and I have not seen any that are sound sensative.
NMDante
  • Aaargh!
Neon Lights
« Reply #3 on: August 05, 2001, 04:45:00 PM »
Angle the neon on the bottom of the case.
As for the EL lights (flexible neon cable) they would work, but they aren't very bright.  The sound sensitive liquid neons aren't that bright either, tho.
I personally use a CC (cold cathode) light, and it's brighter than hell.
CoDe_MaStEr_JoN
Neon Lights
« Reply #4 on: August 06, 2001, 12:13:00 AM »
I cant Stick the Neon light at the bottom like everyone else cause it is soo big some of it sticks out the drive bay and wont fit at the bottom.
i am thinking about getting on of those cold cathode rays
anyone know what kind of price range i should be looking at?
Neon Lights
« Reply #5 on: August 06, 2001, 03:41:00 AM »
aren't the cold cathodes 15" as well?
CoDe_MaStEr_JoN
Neon Lights
« Reply #6 on: August 06, 2001, 06:09:00 AM »
hahhahahaha
really 15'?
i guess just a regular 10' neon
anyone know where i can get one cheap?
NMDante
  • Aaargh!
Neon Lights
« Reply #7 on: August 06, 2001, 11:10:00 AM »
My CC is only 12 inches long, I believe.  Hold on I'll go look....yup, about 12 inches only.
ripper_x4
Neon Lights
« Reply #8 on: August 09, 2001, 09:58:00 AM »
where did you get alhold of your CC light?
Glow
Neon Lights
« Reply #9 on: August 09, 2001, 12:50:00 PM »
mine is 7 inches.  wait, what are we talking about again?  :P
Page created in 0.062 seconds with 19 queries.
