  • August 21, 2019, 07:24:22 PM
Author Topic: HHD lite  (Read 473 times)
icyxwindz
HHD lite
« on: August 18, 2002, 08:43:00 PM »
i knoe i saw this answer sumwhere else in the forums but i tired looking for it again and couldn't find it.  if i wanted to swtich my HDD lite to a blue one.. which size, volt LED do i need and do i need a resistor? and basiclly i juss cut the tip of the orange part and solder the new one on right?
RentonLovesJunks
HHD lite
« Reply #1 on: August 18, 2002, 08:52:00 PM »
ummm. well. ummm. the cutting thing. im good at cutting. ok what you want to do is just below the orange part, cut there. make sure the wires are seperate. and i think you want a 3 volt. and the size should match the size of the old one.
Falandar
HHD lite
« Reply #2 on: August 19, 2002, 02:00:00 AM »
Try this http://www.gideontech.com/guides/led_replace/index06.shtml"> guide  It's from some website, I dunno, never heard of them.  Gidenheck or something like that :)  Good guide that should be what you're kinda looking for I think.
-Sean-
Page created in 0.065 seconds with 19 queries.
