  • January 27, 2020, 11:45:00 AM
Author Topic: Do These Exist?  (Read 479 times)
NJOperaman
    • http://www.cabarettheatre.org
Do These Exist?
« on: August 13, 2002, 07:13:00 PM »
Is there a product that acts like a multi-outlet power strip for your cpu power sourse. Sorta like a large strip of 4prong cpu power outlets that you could connect all your periferal stuff to IE extra fans, CCFL, and stuff like that. Im having a cable management problem, and I think a product like this woult be awsome. And if this doesnt exist, please don't steel this ideal and patent it. That would be mean.
pewterpez
Do These Exist?
« Reply #1 on: August 13, 2002, 07:23:00 PM »
sounds like just a modified fan bus....with molex instead of a terminal strip....
brutal
    • http://www.brutal.tk
Do These Exist?
« Reply #2 on: August 13, 2002, 08:12:00 PM »
its easy to wire up, but im not sure it exists for retail.  The hardest part is finding surface mount molex connectors if you want to use a project box.
Page created in 0.076 seconds with 33 queries.
