  • July 04, 2020, 01:19:29 PM
Author Topic: Dam it..... TOO MANY CHOICES!!!!!  (Read 2772 times)
Kuchuk
« on: August 04, 2001, 10:48:00 PM »
I got no clue what cpu cooler to get on my athlon 950... i recently bought the orb dragon 3 but found it way too loud, i was tipped that a resister would help, but besides that i want to know what others suggest about a cooler that balances out between price and NOISE! thanks
CoDe_MaStEr_JoN
« Reply #1 on: August 05, 2001, 02:27:00 AM »
This is just a suggestion you dont have to follow it but you could.........
take of the side panels of your comp and plug in a fan into the wall and let er rip keeping you and your comp kool.......
it is just a suggestion i did this for sometime then i noticed alot of dust all inside my comp........ so i built a new comp
muuuuuuuhahahaha
« Reply #2 on: August 05, 2001, 02:51:00 AM »
you might want to look into the zalman coolers, they cool decent, and are quite.
TitoJackson
« Reply #3 on: August 10, 2001, 06:55:00 PM »
If you don't want to OC, just buy the basic coolermaster one.
Page created in 0.176 seconds with 33 queries.
