  • July 14, 2020, 08:54:13 AM
Pages: 1 2 [3] 4   Go Down
Author Topic: How about an AIR CONDITIONED COMPUTER...............  (Read 9779 times)
« Reply #20 on: August 07, 2001, 02:04:00 PM »
ahh ok.  That explains it, but is that a little overkill?
Antacus
« Reply #21 on: August 07, 2001, 02:21:00 PM »
Overkill would be when you live in Dallas, mid-Augest and you have all the windows open. You are sitting in front of yer PC wearing a ski jacket, mittens, scarf, hat, and ear muffs. :D
General Gossip
« Reply #22 on: August 07, 2001, 02:38:00 PM »
do remember that a peltier has a hot side too... so it will also generate a whole bunch of heat, and where does that go? :)
NMDante
  • Aaargh!
« Reply #23 on: August 07, 2001, 02:45:00 PM »
I never said my friend was stable.... :)
He is now playing with some sort of watercooling.  He's trying to make his own waterblock with a 4x4 inch block of aluminum.  I didn't ask how/where/why he got the block, but he did.
He is now in the process of drilling the holes (venting) and trying to find a way to put a copper insert in it... ????
Nuts!  :P  But who am I to stop him?!?
General Gossip
« Reply #24 on: August 07, 2001, 02:51:00 PM »
I think its cool... homebuilt watercooling rulez.. wish I had the skills/guts to try it out...
NMDante
  • Aaargh!
« Reply #25 on: August 07, 2001, 09:48:00 PM »
It's not skillz that he has, just some pretty damn sweet tools!
airkilla09
« Reply #26 on: August 07, 2001, 10:19:00 PM »
Can you just add some sponges into the hose to soak up the moisture. nd also had another case fan to blow out all of the AC intake. That way air flow is kept and no air is left to settle and condensate. ACs should be turned off about 5 mins the pc is turned off, that way it can be left to remove all cold air.
NMDante
  • Aaargh!
« Reply #27 on: August 08, 2001, 12:01:00 PM »
I don't know if a sponge would help soak up much of the moisture.  It will if it isn't soaking up too much, I guess.
I would leave the AC unit and CPU on all the time, and never shut it off.  That way no condensation.
Another outlet for air flow would be good, I guess.  I wish I knew for sure.
« Reply #28 on: August 08, 2001, 01:25:00 PM »
the air coming off an ac unit should be dry....  thats how they work, the take the moister out of the air making it colder....
SaiyaSurge
« Reply #29 on: August 27, 2001, 09:46:00 PM »
Just buy a mini fridge and put your computer in there, btw make sure you have enough room for a 6 pack, gamin and drinkin to mix :)
Pages: 1 2 [3] 4   Go Up
Page created in 0.085 seconds with 33 queries.
