  • June 06, 2020, 01:50:11 AM
Pages: [1] 2 3 4   Go Down
Author Topic: How about an AIR CONDITIONED COMPUTER...............  (Read 9651 times)
Kuchuk
« on: August 04, 2001, 08:59:00 PM »
I got an idea to buy or build a large whose about 3-4 in. wide and connect one to my ac and the other to stick somewhere into the pc... what ya think
« Reply #1 on: August 04, 2001, 10:01:00 PM »
would work depending on air flow pretty well I don't know if condensation would be an issue, prolly not, but you never know
« Reply #2 on: August 05, 2001, 10:01:00 AM »
wouldn't condensation come into the picture? Or am i talkin doodoo out of my mouth :)
« Reply #3 on: August 05, 2001, 02:01:00 PM »
well, I was thinking the same thing, except air conditioners take moisture out of the air... thats how they work.... and since the his case temp would also be lowered there wouldn't be risk of condensation.  besides, have you ever seen your registers (if you have central air) have condensation on them, i haven't...
NMDante
  • Aaargh!
« Reply #4 on: August 05, 2001, 04:52:00 PM »
Condensation shouldn't really be a factor, unless the AC unit is an evaporating type (ie. swamp cooler systems).
I've seen systems jammed into refidgerators, but they (the guys who built it) said that condensation only occurs if and when the fridge is shut off.  Same thing might happen with AC cooled systems when they are shut off, since the components might be well below 0 degrees.
« Reply #5 on: August 05, 2001, 05:14:00 PM »
well below 0 degrees my arse.  I highly doubt they would be below freezing....
NMDante
  • Aaargh!
« Reply #6 on: August 05, 2001, 10:46:00 PM »
With some of the AC units around here, I'm betting that they could get to 0 degrees easily, especially if AC unit is blowing straight into a case.  With nothing else to cool (ie. a room) it will make that baby cold.
« Reply #7 on: August 05, 2001, 11:53:00 PM »
cold maybe, 0 I don't think so....
plus all you would have to do is a little test just hookup the system to your empty case let it run, if there is condenstation, ice crystals forming, then you might wanna cut down the supply...  other wise it sounds like a good idea.
Antacus
« Reply #8 on: August 06, 2001, 09:53:00 AM »
On a smaller scale what about using one of those Peltiers on the intake. Just wire up something like a peltier/hs/fan combo and slap that in the front of that case. Wouldent that cool the intake air like an AC until would? I would think that would be a little bit smaller then a window AC until sitting in front of your puter, plus a little quieter.
I can picture someone goin to a LAN party and lugging an AC until into the room. Man, that would have me rollin on the floor :)
« Reply #9 on: August 06, 2001, 11:13:00 AM »
hte problem with putting a peltier in your case is that it does condensate....
Pages: [1] 2 3 4   Go Up
Page created in 0.19 seconds with 33 queries.
