  • February 18, 2020, 06:10:18 AM
Author Topic: YY Cube Cooling  (Read 585 times)
dreadful
YY Cube Cooling
« on: August 08, 2002, 10:36:00 AM »
Alright Im having a little problem with cooling and im thinking its airflow in the case but not sure. I have a YY case with two 60mm fans on the right blowing in, one 80mm fan on the front left blowing in and a 120mm fan at the back right blowing out. I cannot seem to get my temps down below 51c without the sides off, with the sides off it only goes down to 47c. My setup is below if anyone has any suggestions please let me know.
Tyan Mpx
2 x 2000+ mp
volcano 7+'s
1 gig simpletech ram
tt memory coolers
gf4 4600ti 128mg
yy cube case
shizno
YY Cube Cooling
« Reply #1 on: August 08, 2002, 11:19:00 AM »
i suggest replacing those little 60mm screamers with some nice 80mm's because of the size you cut it already...also the brand name helps....panaflo is good....sunon is ok.
maybo you should check all the cfm's of your fans and add another rear one to fit the cfm and make it even
ClearCaseMan
    • http://www.casemodman.com
YY Cube Cooling
« Reply #2 on: August 12, 2002, 05:41:00 PM »
I would think using the 120 comming in and the others out would be better it would allow you to reach static preasure to maximize your flow
Page created in 0.097 seconds with 33 queries.
