  • August 03, 2020, 03:38:46 AM
Author Topic: Supercooling SMP Systems  (Read 2191 times)
dogstar
« Reply #10 on: August 08, 2002, 11:39:00 PM »
if you get two pumps like you plan, and one decent sized heater core... er radiator you might not need a separate resivour.
perhaps go to http://www.summitracing.com, and take a look at some toys...
heres a catch can, if you really need a res, and its made to cool fuel, so it should work alright to cool off coolant
http://store.summitracing.com/default.asp?target=%2Fproduct%2Easp%3Fd%3D5%26s%3D52%26p%3D3930%26searchtype%3Decat
they also have a bunch of pretty cool radiators, and some of them would look damn trick on the side or back of a case
http://store.summitracing.com/default.asp?target=%2Fsection%2Easp%3Fd%3D5%26s%3D194
thats my suggestion, if you wanna trick this unit up, and make it perform
supra: why drive when you can fly?
honda: cause everyone needs a winter beater.
shizno
« Reply #11 on: August 08, 2002, 11:55:00 PM »
those are damn expensive radiators man! i dont think he wants to spend that much.....you can always go to a junkyard but here i found a very powerful pump for the size
http://www.crazypc.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=120199&Product_Code=9332
im not exactly sure if it is submerible...i think it should be
relayPoint
    • http://error404.nls.net/version2/
« Reply #12 on: August 09, 2002, 01:47:00 PM »
Radiator is coming from Griffin. (http://griffinrad.com/)
It's out of an S351 Saleen in a junkyard. Either that or I'm going to be using two transmission coolers from '88 Ford Broncos. (These trans coolers are 12"x8" single core, high density.)
As far as pump, I'm probably going to use fully submersible pond pumps. They're cheaper, easy for me to get, and I'm somewhat familiar with them.
Resevoir is going to be custom-built. Lexan and lots of pro-plastic welding stuff and O-rings and such.
Most of the work is going to be custom either way though. ;P
shizno
« Reply #13 on: August 09, 2002, 03:31:00 PM »
this is gonna be very expensive......another option is to just buy a vat like vapochill but find some smart person to make it split to dual.....now thats some crazy cooling
relayPoint
« Reply #14 on: August 09, 2002, 03:34:00 PM »
Hehehe.. oh hell yes. I told the guy that he's gonna be looking at $1000 for just the cooling system, without the case. And one HELL of an electric bill. He just shrugged, said he had $4k saved up for it all. (Bastard.)
I was looking at these (http://www.tecooling.com/aafaq.htm) today... hmmm...
GrendelPrime
« Reply #15 on: August 09, 2002, 05:40:00 PM »
Shizno, that's a serious pump you linked to, already set up for a molex, and moving 180gph at a 4ft head.
I can't help but think it would be a bit on the noisy side though.
Nice find, thanks.
relayPoint
« Reply #16 on: August 10, 2002, 09:22:00 PM »
I dig the pump. He's leaning towards the same case I have. (See linkage in sig.) What's the best positioning for the pumps? I'm figuring above the PSU or below the driv****s. Suggestions?
shizno
« Reply #17 on: August 10, 2002, 09:49:00 PM »
yo this may sound bizerk but...if he said he'd spend 1000 on a cooling system....get two VATS they are like 500 each so it would just fit the budget.....each one cools the cpu to -15c and below.....ultimate in cooling....and you can put them in that case...one on bottom underneath driv****s and read a tutorial about fitting one on top by psu....its very possible so it wouldnt be that hard also less demanding of a power supply is needed as opposed to dual pelts
Cooling performance
Average Temperature reading
Approx. -12C / -10.4F
Readings taken from a VapoChill bare bone mounted with motherboard, memory graphics adapter, hard drive and P3 800MHz CPU running at 1136MHz. Measurements are done on the middle of the evaporator wall.
Temperature readings may vary due to different heat dissipation from different processors. Also core speed and core voltage has influence on the temperature readings.
Power Supply Requirements
Start-up
Cut-in voltage: 10.9 V
Peak current @ 12 (50 ms): 12 A +/- 1 A
Peak current @ 10 (50 ms): 14 A +/- 1 A
Continuous
Cut-out voltage: 9.6 V
Current @ 12 V and 100 W heat load: 6.6 A
relayPoint
« Reply #18 on: August 10, 2002, 10:01:00 PM »
Linkage for VATs, please? :)
shizno
« Reply #19 on: August 10, 2002, 10:03:00 PM »
well http://www.vapochill.com   read the forums...those guys specs are SICK!!! like a 1.6ghz pent at 2.8ghz with temps around -9c lol thats just crazy
Page created in 0.07 seconds with 33 queries.
