Hi,
I know that this is an older thread, but maybe someone still reads it ....
I built this case last week (bought at SVC.com, case was no-name, but it's the same case as I can see from the pictures and DesignComp site; the documentation is identical as well....
Anyway, I have everything fitted nicely except the expansion cards - the screw holes & the bracket holders are about 1-2mm off, what is enough to make the cards not fit right, or better, not to be able to tighten the screws easily. I was just curious whether anyone else ran into similar problem?
I disassembled the case and rearranged everything for the second time (again, with all case screws loose as before, still the same problem.
Anyone?
thx
dave
