  • June 06, 2020, 09:49:21 PM
Author Topic: Xtasy Geforce4 MX 420 chipset cooling  (Read 941 times)
spy_spirit
« on: July 08, 2002, 04:11:00 PM »
I want to add a chipset cooler to my Xtasy GeForce 4 MX 420 (64MB) but I don't know wish one.
Any suggestion?!
p.s: I'm a newbie in modding.
arcsylver
« Reply #1 on: July 09, 2002, 02:29:00 PM »
I have a PNY Verto GF4 MX 420 and I use the Vantec Copper Iceberq.
Here's the link to the Vatec site.
http://vantecusa.com/iceberq_copper.html
I got mine here:
https://www.bestbyte.net/Category.cfm?CategoryID=6&Keyword=
It is at the very bottmom of the page for 9.95. It shows the aluminum version but it is actually the copper.
 Works great on my card and dropped my GPU temps by almost 5 degrees C.
 Almost forgot, Maje sure to get some Arctic Silver 3 to use with that cooler, it is well worth the investment. Don't use the thermal tape that comes with it or the thermal goop.
_________________
Celeron 1 Ghz w/Vantec CCK-6040(Copper X)Antec LED Blue LED Fan on HSF w/60-80 adaptor
MSI MS-6366 Mobo
512 PNY PC133 SDRAM
PNY Verto GF4 MX420 w/Vantec Copper Iceberg
LG 16X DVD
HP 9300 Series CD-RW
Maxtor 30 GB 7200 RPM
spy_spirit
« Reply #2 on: July 09, 2002, 05:19:00 PM »
I already have arctic silver 3 thermal compound so I don't net to buy it but do I need the arctic silver thermal adesive to glue the heat sink?
thx
spy_spirit
« Reply #3 on: July 10, 2002, 12:56:00 AM »
do the thermal take orbs (orange, blue and cristal) cuz I love this nice shiny cristal orb, do the cristal orb will fit on my card?
arcsylver
« Reply #4 on: July 10, 2002, 04:06:00 PM »
As far as needing the adhesive. Does your card have little plastic pins holding the heat sink on?  If it does then you don't need the adhesive.
  As far as the chrome orb goes I don't know. Go to the thermaltake site and check what the dimensions on the heat sink are and then check for the availible space on the card.
 I recommended the copper Iceberg for two reasons.
1. It is REALLY shiny. so it looks cool
2. it is also all copper and small so it will fit almost any video card.
  Anyways good luck man. I personally like the cooler I got better cause it is quieter than the orbs.
spy_spirit
« Reply #5 on: July 10, 2002, 06:50:00 PM »
ok thx
Page created in 0.092 seconds with 33 queries.
