  • August 16, 2022, 07:57:17 AM
Pages: 1 ... 4 5 [6]   Go Down
Author Topic: Guide: Powering Up a PSU  (Read 94689 times)
outonanisland
« Reply #50 on: December 15, 2003, 12:29:34 AM »
ok ieR   the green has current running through it, 3.8 volts, the black is an earth, im trying to run two atx psu's as well, one modded with no plug but has teh green and black and molex connectors and another that is standard and plugs into a mobo, now i have a question about just splicing the two green and two black together, on the first page of this particular topic someone said it causes a little bit of damage to both psus, exactly how much damage? and what about the mobo, each psus puts out .5 amps, these combined will be a whoel amp could that possibly fry the mobo/?
TIME FOR A SMOKE!!!
To-mod-or-not-to-mod
« Reply #51 on: May 12, 2004, 10:25:27 AM »
My toolkit is missing and I was wondering if you could quickly use a paperclip for a hour or two?
« Reply #52 on: May 12, 2004, 12:42:29 PM »
Quote from: To-mod-or-not-to-mod
yup, that will work too.
« Reply #53 on: May 13, 2004, 10:08:00 AM »
thankyou
rico1981
« Reply #54 on: September 13, 2004, 03:38:06 PM »
am i the only one that did this to power a home-made moonlight for my fishtank?
MichelOC
Re: Guide: Powering Up a PSU for a CoolerMaster RS-500
« Reply #55 on: January 28, 2011, 10:37:21 AM »
Hi:
I'm trying to run a CoolerMaster RS-500 (Brand New) follow your instructions, but nothing happends. Also I've been reading some info on the web about PG pin, but still nothing happends. Really, Power Supply tried to start but that is all.
Here the configurations:
1) Only PS-ON to Ground.
2) Only PG to Ground.
3) PS-ON + PG to Ground.
Could you give any idea?
Thanks
Michel OC
« Reply #56 on: January 28, 2011, 01:09:20 PM »
Does it work plugged into a motherboard?
Also, keep in mind, on a 24 pin ATX PSU PS-ON is pin 16 and not 14
Are you sure you are grounding out the proper wire? It should be green.
Baldric
« Reply #57 on: June 24, 2011, 06:19:04 AM »
I have an old FSP200-60P from a 7 year old Hewlett Packard PC.
I have tried connecting the Black and Green Pins on the 20 pin P1 mother board block, but does not work!  :(
ANYONE KNOW HOW TO GET AN OLD ONE UP ???
« Reply #58 on: June 24, 2011, 07:30:06 AM »
Place a device on one of the molex connectors and then try the black/green trick.
Baldric
« Reply #59 on: June 29, 2011, 10:53:49 AM »
 :lol:
Success, It helps if you are not red Green Colour blind !
Thanks again for your help
Pages: 1 ... 4 5 [6]   Go Up
Page created in 0.291 seconds with 49 queries.
