  • July 04, 2020, 12:45:41 PM
Author Topic: Playing around with Athlon Bridges... OUCH!  (Read 3364 times)
Kuchuk
« on: August 02, 2001, 09:13:00 PM »
here's the deal :roll: , i got only one way to o/c my pc.. with L bridges on the cpu, i wanna know what i can use to cut and connect themm(tools)... the cheaper the better, anything around the house is Perfect. :D
Kuchuk
« Reply #1 on: August 02, 2001, 09:15:00 PM »
[/if it works, overclock it, if it doesn't, smash it, but whatever you do have FUN]
« Reply #2 on: August 02, 2001, 09:51:00 PM »
you can use an engraver to cut the lines if you have a steady hand.... or go to a jewelry store and see about a diamond chip... I dunno if an exacto knife would work but it could be worth a try... first check to see if you need to cut any bridges, it *MIGHT* end up that you only have to add bridges...
Oh and to connect them you can use a mechanicla pencil, or a conductive pen.
_________________
Tbird 1.4 @1.53
512 Megs PC166
Geforce2 GTS 64 Meg
Onboard Sound w00t!
16X DVD
[ This Message was edited by: winterstick on 2001-08-02 22:52 ]
j0m
    • http://www.syntheticmonkey.com
« Reply #3 on: August 08, 2001, 11:44:00 AM »
You say you're trying to overclock an Athalon. What kind of Athalon? I have a T-bird, and to get that overclockable all I needed was a sharp pencil. The graphite in the pencil has enough conductivity to connect the bridges.
« Reply #4 on: August 08, 2001, 01:30:00 PM »
well on his the mobo didsn't support fsb control, or multiplier changing :/
Oh I found a product for all you people with gay boards... http://www.plycon.com/goldsock.htm
Page created in 0.161 seconds with 33 queries.
