  • July 05, 2020, 09:37:48 AM
Author Topic: Lenovo K320 Ice Series Mod  (Read 14331 times)
jj_sky5000
« on: December 06, 2010, 08:08:50 PM »
Hello all, This mod came from a concept  that I submitted For the lenovo Mod Contest.     http://www.whatsyourideaoffun.com/us/meet-the-mods
My design was  selected as one of the finalist and  Lenovo  sent me  Thier Ideacentre  K320 PC  to mod to my heart desires.    The winner of the contest gets to  showcase thier mod at the 2011 CES at Las Vegas.
I had a few ideas  in my head, and I sent them a rough design of a  PC  encased in ice  for my initial entry in the contest.
K320 Specs
CORE_I7_870_2.93
8G_DDR3_1333
ATI_RADEON_HD5970_PCIE_2G
1TB_7200RPM_SATA2
Blu-ray Disc combo
The main transformation  of this Mod is to replicate the Lenovo K320 chassis  into a   Liquid acyclic shell   to give it the appearance that the K320 was encased in ice.
Features:
Custom  mold made from the original chassis to create the Acyclic Ice replica
Feature as many of the original  details from the original chassis, keeping the screw less system as well as the easing to use hard drive enclosures.
Adding special lighting through out the system  to show the performance modes of the fans all throughout the case.  Red, Blue, Green
Adding custom water cooling and reservoir to keep all the components running at optimal overclock while keeping the system cool.
ATI Eyefinity System with  3 28 " Monitors.
Part List
Molding & Building materials
1 x Silmar 41 Clear Polyester Casting Resin (5 Gallons)
5 x 75-80 RTV Liquid Urethane Mold Rubber 3lb Kit
2 x 3M Double Strap Dust Mask
2 x Poly-Ease 2300 Mold Release 12oz
1 x Disposable Latex Exam Gloves Large
1 x Disposable Tyvek Coverall Extra Large
Components
1x XSPC Dual 5.25" Bay Reservoirs w/ Blue LED Light - Clear / Silver / Black
1 x MC-TDX Block for LGA 1156 i3, i5, i7
1 x LED Lightstrip with Controller and Remote
3 x LED Lightstrip - 12 inches (30cm)
2 x DD Fillport Options:Fillport Color: Bright Blue Anodized
1 x Custom Laing D5 -Bitspower Black Sparkle
6 x ENERMAX T.B. VEGAS TRIO 120mm
1 x Mod/Smart Professional System Sleeving Kit - White
2 x Feser One Non Conductive Cooling Fluid - 1000 ml - UV Clear / Blue
1 x Black Ice GT Stealth 360 Radiator - Blue
6 x Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Tubing - Clear / UV Blue
1 x EK Radeon HD 5970 VGA Liquid Cooling Block - Nickel (EK-FC5970-Nickel)
1 x EK Radeon HD 5970 VGA Liquid Cooling RAM Backplate - Nickel -
A Picture of The liquid resin that i will be using
A few design pics
With the side panel off
And the other side
jj_sky5000
Re: Lenovo K320 Ice Series Mod
« Reply #1 on: December 06, 2010, 08:10:00 PM »
Started  working  hard this weekend on the project  after a few setbacks.
First thing was disassembly   of the pc  and make a few adjustments.
1st adjustmnet  i wanted to move the power supply  & hard drive cage to the bottom of the case to free up the Top  for a 240mm radiator.
Time to start removing some rivots.
Need to  make a few cuts  To make room  for a 120mm Fan on The bottom & Replace  the bottom base with arcylic
Also Made room toward the top for the dual bay reservoir
Stayed tuned for more modding !!!
jj_sky5000
« Reply #2 on: December 06, 2010, 08:15:02 PM »
Well I  made some good progress over the past week and through the weekend and the frame should be completed this coming week,
Cut out the  power supply  support out,  so it can be moved to the bottom of the case and re rivoted to the frame.
I am also moving the Blue-ray and  all in one reader   to the bottom of the case. teh reason i chose it on teh botton  instead of standing up or reaching  to reach all of the i/o ports and rom.     So i started  cutting out   the levono tool-less  supports
Made a little room for the hard drives and Cd rom supports on the base
Need to make a few more cuts to the front panel, cd  and hard drive fram supports
re attaching  the Cd-rom and hard drive brackets  back together
A little test fit
More to come.
Please go check out all of the neat mods at
jj_sky5000
« Reply #3 on: December 06, 2010, 08:15:58 PM »
Made alot of good progress over the last two days  completeing the frame  and prepared to  add teh Primer.
I wanted the frame to look as thin as possible so its no impeading the view when looking through the resin, I was pretty please ho wthe skelton looks.
The hard drive bay and Rom bay  was really hard  to compact and rebuild. but I kept the screwless features intact.
A few test fits
a nice clean look
A few More items came in today
The Ek  5970 Waterblock and back plate
and some awesome BILLET MACHINED ALUMINUM "Diamond Knurl" CASE FEET
From MNPCTECH.com
Thanks  for looking !!!!
Also   dont forget to go cast a vote at http://www.whatsyourideaoffun.com/us/meet-the-mods
I can use all i can get.   no registration , click teh mod and vote!!!!
jj_sky5000
« Reply #4 on: December 06, 2010, 08:16:41 PM »
A nice way to start the 4 day weekend!!!!
Frame is primed and ready for to be painted metallic
Ok now to the tricky sticky stuff
Making a mold  of the new front panel to pour the Clear Resin into !!!
 in goes teh molding materal
Letting all the bubbles rise
 took of the bottom to release the front panel
The completed Front panel Mold
A nice icying effect for the resin
Last but leaset did a little ecting
A little lighting effect for the side panel
Do you want to see this case at CES  go cast a vote for it at http://www.whatsyourideaoffun.com/us/meet-the-mods
click explore and vote!!!!  no registration
jj_sky5000
« Reply #5 on: December 06, 2010, 08:17:19 PM »
Aluminum Foil + Resin =  ICE ICE Baby
Front Panel
Top, Back , Tray
A few Sneak peeks
Thanks for Looking !!!
Dont forget  to Head over to The Lenovo Mod Contest And cast a Vote
Just click Vote for this mod, No registration
http://www.whatsyourideaoffun.com/us/content/k320-ice-series
jj_sky5000
« Reply #6 on: December 06, 2010, 08:18:04 PM »
More pics !!!!!!
Added The Case feet  from MNPCTECH.com   They look so good
Prepared  base for the fan hole for the power supply
Test fit the powersupply
Cut the Tray to size
Routed out the front panel using a table router  for the dvd , reservoir and lenovo lighting switch
test fitted the reservoir
Almost look like a pc   cut & added  theMB tray !!
Attached the top and front panel,  with black screws
Still Undecided to go with black or silver Screws  ??  Post a your opinion
Dont forget to go cast a vote   to see this case   at CES !!!
jj_sky5000
« Reply #7 on: December 06, 2010, 08:19:48 PM »
Thanks for all your Input  !!! and The great compliments
Went with Silver /stanless steel lol   screws!!!
They go with the case very well
Currently Got The sides panels mounted
Inside look of  the lenovo K320  Ice mod
Started Finishing The Front and back panels  Almost ready to assembly
Up next   The fan cut outs!!
Dont forget to check out  Lenovo New website    http://www.whatsyourideaoffun.com/us/
And  cast a vote to see this MOD and 2011 CES!!!
Just click on Vote for this Mod !!!
jj_sky5000
« Reply #8 on: December 07, 2010, 02:03:24 AM »
Small Update, The final few cuts     Fan holes
MNPCTECH  offers  some great templates   for rads and grills!!!
I use one of my favorite tools  Teh Hole Cutter  :)
Side panel Fan
Finalizing The Back panel !!!
Cleaning and test fitting up next !!!
jj_sky5000
« Reply #9 on: December 09, 2010, 03:14:27 AM »
Small Update
Cleaned all the panels
Added The MB tray
Added the 5970 Ek waterblock
added the rad and fans
Please help me out by Casting a vote for teh lenovo building contest  at http://www.whatsyourideaoffun.com/us/content/k320-ice-series  I am only 300 votes behind
Thank you
Page created in 0.082 seconds with 33 queries.
