  • January 25, 2020, 04:10:06 PM
Author Topic: help adding extra sata wd 1tb harddrive not working  (Read 5693 times)
Soldner
« on: August 09, 2010, 07:42:47 PM »
Hey guys I just got a WD 1tb caviar green hard drive for some extra space and cant get it to work. I currently have a intel 80gig ssd as my primary but when I plug in my new drive it hangs at the windows boot screen and never gets past it. It recognizes it in the bios but just hangs after that... Any ideas...my MB is a asus p7p55d
YucA
Re: help adding extra sata wd 1tb harddrive not working
« Reply #1 on: August 10, 2010, 06:29:25 PM »
boot the PC then plug the drive in.
Soldner
« Reply #2 on: August 11, 2010, 09:05:21 PM »
I tried plugging it in after I started up and a message comes up saying "if this device is a port multiplier some about port 0 and port1 blah blah blah" I dont get it, Intels matrix storage console says hard drive functioning ok but drive dosent show up under computer
Soldner
« Reply #3 on: August 11, 2010, 09:46:09 PM »
ok i unhooked a ide harddrive i had going and now it boots with the new sata being recognized in bios but doest show up in windows and ideas?
« Reply #4 on: August 12, 2010, 07:18:32 AM »
To get it recognized in Windows go to the Control Panel -> Administrative Tools -> Computer Management.  In there select from the left panel Disk Management (it may be hidden under Storage).  If all is set up correctly, you'll likely see your drive in the bottom portion of the center panel.  You'll have to right click, Mark Partition As Active.
You may have to change the drive letter around to what you like and format as you like, but that'll get you what you want.
Soldner
« Reply #5 on: August 13, 2010, 04:24:40 PM »
blafrisch....you have have solved yet another one of my computer problems, thanks a lot.
Page created in 0.054 seconds with 33 queries.
