  • July 21, 2019, 04:33:26 AM
Author Topic: Vinyl dye question  (Read 4444 times)
Aglar
Vinyl dye question
« on: May 06, 2010, 01:12:50 PM »
Hi all, been a long time, glad to see this place is still alive and kicking.
I recently bought a cheap HD camcorder and works pretty well, but it only came in one color: blue. Nothing against blue but since all my other electronics are black I was thinking about trying to vinyl dye it.
I've worked with the stuff on things like keyboards and mice, but this plastic has a fairly shiny finish (clear coat?) and I wasn't sure how effective it would be. I was wondering if it would have to be sanded before applying.
Attached are a couple of pics that I'm hoping will show what the finish is like.
Thanks!
« Last Edit: May 06, 2010, 01:16:51 PM by Aglar »
Re: Vinyl dye question
« Reply #1 on: May 09, 2010, 04:00:06 PM »
Nothing wrong with that, I like the color.  It's been my experience that a finish like that won't get along with dyes.  I have an external hd enclosure that had a nice shiny white finish, and I wanted to dye it to match the rest of my pc.  I cleaned it well with lacquer thinner which also took the shine off, and then sprayed it per the directions.  The finish looked good until I touched it, when it proceeded to peel right off.  It's still usable,  but looks like hell.  If I were you I would live with it the way it is.  Of course, you may have better results, and if so, let us know.  Good luck!
« Reply #2 on: May 09, 2010, 05:15:25 PM »
I would leave it as it is right now.
« Reply #3 on: May 09, 2010, 07:34:33 PM »
That looks like a painted plastic, and that the dye isn't going to be able to adhere very well.  Of course you never know until you try.
Aglar
« Reply #4 on: May 31, 2010, 01:53:13 AM »
Thanks for the replies all, think I'll be keeping it as-is. Could be worse, I suppose ;)
Page created in 0.079 seconds with 19 queries.
