  • August 16, 2022, 04:26:54 AM
Author Topic: Unstable HD?  (Read 6431 times)
Styles
    • http://www3.sympatico.ca/lampskin
Unstable HD?
« on: April 29, 2010, 06:33:27 PM »
I'm trying to diagnose a rather mysterious problem.  Perhaps one of you fine gentleman would be of assistance...
Every once in a while, my computer seems to freeze every 3 minutes for about 1 minute.
It's so hard to diagnose, because obviously I can't use task manager to check what services are running while the computer is frozen.  Also, it doesn't do this every time, but only occasionally.  A reboot usually fixes it.
I'm going to run AVG, but my last scan was clean.
Also, I don't know if it's related, but every once in a while, the system will reboot by itself after first logging into window upon the initial boot sequence.
Maybe a power surge or something could be causing this?  I've got a reliable UPS, I think...
My thoughts:  New HD?  I've tried defragging the HD, and didn't seem to help.  My HD is about 7 yrs old.
I was actually thinking of buying an external HD and backing up, then doing a HD swap and seeing if it helps.
Anyone?
Re: Unstable HD?
« Reply #1 on: April 29, 2010, 07:16:40 PM »
There are many things to test, but if you think that's your HDD, then unplug it and boot with any live CD.
Styles
Re: Unstable HD?
« Reply #2 on: April 30, 2010, 06:22:22 AM »
you mean like Knoppix?
So if it booted knoppix ok, then that would point to the faulty HD?
I guess even if it did boot knoppix ok, that would still mean that it could be some software or OS problem, not necessarily HD, right?
YucA
Re: Unstable HD?
« Reply #3 on: April 30, 2010, 11:53:40 AM »
Knoppix, ubuntu, fedora, etc all have Live CD variations - any option will work.
If it boots with a live CD and everything is kosher, then yes i would say its either the HDD itself or something in the OS is crapped; maybe a driver?...
Sooo, what i would do it run the live CD, and if that solves your issue i would first fdisk that 7yr drive and format/partition the badboy and install a fresh version of your OS.  That still doesnt solve your issue them get a new HDD and do step one....
That doesnt work, you either have MOBO or RAM issues.
easy enough...
Re: Unstable HD?
« Reply #4 on: April 30, 2010, 03:01:30 PM »
The first thing I would do is take a look at the SMART data from your hard drive.  That will, hopefully, tell you if there are any major problems.  I personally use SpeedFan's hard drive panel to do this.
Page created in 0.381 seconds with 34 queries.
