  • July 23, 2021, 04:30:31 PM
Author Topic: Project: Lanmunition  (Read 19792 times)
DeadP1xels
Re: Project: Lanmunition
« Reply #10 on: February 21, 2010, 01:54:17 PM »
Finally updates! :)
Done some work on the Machine and Monitor today so here it is!
reinforced the back panel that snapped with a piece of angled metal riveted
back panel mounted on standoff nuts
sadly the cold cathodes i got didn't fit so it they'll go in the pile for "Lanmunition V2" instead we used this light
Hd activity mounted on a standoff behind fan so you can see it nicely when its spinning
got all new bolts in the fan and grill
added a reset switch and soldered some stuff up
heres the back so far hoping to add some grill for ventilation this will be sprayed black and cleaned up a little
most of the front soldered on just need some cleaning and tidying up not permanent because we still need to finish the front panel and paint
finally time to see if we have killed anything in the process so it was time to hook up some stuff and switch it on!
booted fine everything seemed to work except the light it had a mercury switch that thought to have caused the problem but was later found out to be the terminal in the socket which was easily fixed just solder straight to the bottom of the lamp :D
remeber the monitor? well atlast we had the time to cut all the holes we needed
power
video and switch
connected and boom it works!
temporarily sitting on top
you can see the light behind the fan
so far with the monitor
all i have for now im hoping to get most of it finished in the next 2-3 updates
Thanks for reading!
« Last Edit: February 21, 2010, 02:02:57 PM by DeadP1xels »
DeadP1xels
« Reply #11 on: February 23, 2010, 03:18:33 PM »
I figured i should post this before i forget
something finally arrived :)
http://www.youtube.com/watch?v=0CXWDdM0tRU
sorry for lighting it was evening time i got it
Heres some images of the stuff for the people not willing to click a link
Mnpctechs products are truely amazing they are amazing quality my pictures are pretty crappy but every angle on the grill is chamfered perfectly smooth
If you have the money buy one! a perfect addition to anyones case 1/2" aircraft aluminum no need to paint it the finish is pure brilliance. possibly the most extreme fan grill on the planet!
not sure if i'll use the overkill grill on this build or the V2 build i think V2 because i have no room on V1 and its just to wasteful for this one
DeadP1xels
« Reply #12 on: February 27, 2010, 11:38:05 AM »
was just playing round with some monitor ideas i still have the top of the case not sure if i will use it because it never really held together well there needed to be something between the cases to stop them from falling apart using cable ties to keep the latches down.
theres good news and bad news about this the good news is its not coming apart for nothing the bad thing is .... well its not coming apart for nothing!
flipped over and it makes a good base
i'll probebly be making a bezel from angle aluminum (idea from coffeejunky) im not to happy about paying 12 for it though
Thats all :thumb:
DeadP1xels
« Reply #13 on: March 14, 2010, 01:45:22 PM »
Started some painting so heres what i got so far seeming im not getting new paint until next weekend :(
old can found at my dads work 3/4 full
got my mod bag out :)
painted the underside of the latches first can you tell the difference? :P
need to fix a few areas that did'nt go so well
never done the curled latches
only got the top of the top layer done
again needs finishing up
love the way plastic-kote paints are you can lay it on pretty nice and it won't go all horrible some places did a little bit but with a rub down and repaint you don't notice the difference!
Well thats all i got for now going to add the mesh to the front and stuff soon so be ready for more updates aswell as finishing painting!
Thanks for looking :)
DeadP1xels
« Reply #14 on: April 10, 2010, 02:50:29 PM »
Updates!! WOOOO
One of the Bits of paint from the last time layed on to thick and i was'nt so happy with it so i went over it again you can see how it took off everything down to bare metal and that was a few swipes of some emery
Mnpctech U channel Moulding
6ft of Mnpctech U channel moulding
Used some Mnpctech Moulding for the cable holes to stop the cables rubbing and cutting
metal pieces where rubbing so used some felt pieces on there :)
screen cleaned
for carrying
More to com
DeadP1xels
« Reply #15 on: April 10, 2010, 02:53:15 PM »
And more!!!
Aswell as the grill and u channel mnpctech sent me some mesh i was originally intending to use it for ventilation but with the powersupply on the other side bare metal mesh is'nt the best idea to put right next to it in the end i decided why not make a mesh faceplate to add an industrial look to the face of the system
Modder's Mesh
a sheet of 12" x 12" Round hole modders mesh
cut up against the old test panel its looking good!
I decided a few months ago i would'nt waste the overkill grill on this build but instead use it on another version of the same project because this is more of a "can this work" project now i know it can im planning for the future but i still was'nt sure where the grill would fit in
its wider than the opening of the case
this is the only place it could go eventually
Anyway folks more to come tommorow when i paint the front and add some more aesthetic touches to the monitor and system!
DeadP1xels
« Reply #16 on: April 12, 2010, 10:58:14 AM »
Ok some more work :)
Old just did'nt work well still had to be painted but still not as rough as i hoped this is where the mesh comes in
panel empty
yes i cut the mesh with these i have the blisters to prove it :)
filing clean its hard to file clean and take pictures at the same time :P
test fitting
Peeeeeeerfeeeeeect
cleaned up the mesh hole with some u channel
painting done!
Thats better
in the process of jiggling wires i pulled out a few so have to resolder... :(
Doooone!!
Now go from the top picture to the last two i think the change is very effective :)
DeadP1xels
« Reply #17 on: May 14, 2010, 03:47:52 PM »
More done after 1 month no modding! :o time to get this finished!
Heres an update
Last time we left it painted and meshed but i broke aload of wires that needed to be fixed!
What a mess...
Mod box CHECK!
If you buy any tool buy these sell adjusting clamp pliers there a modders best friend :)
i find them easier to use for crimping then these!
Soldering..
All soldered up and crimped :)
Panel back on ready to test!
Lets take it for a test drive :D - does'nt work.... :(
Im no expert but this could be the problem *facepalm*
Thats better! and it boots yay!
What an ugly piece of the case :( really wrecks it
Had some modders mesh still around could i...
Much better!!
Much better
More to come!
DeadP1xels
« Reply #18 on: May 27, 2010, 12:49:58 PM »
Update time
This is the final update before final pics!
Decided to bring up the black in the case more by using dashboard spray
Worked excellently!
Thing is i sprayed it on decking so it leaves a waxy finish i went out there the same day slipped and punched the shed :( i still have the mark almost 2 weeks later!
Managed to get a right angle power cable thing is it was the wrong way still worked though lets me keep the cable in the back all the time
Got some plastic sytrene to make some signs for the front its damn thick and cheap! 1.65 to be exact :)
supplies :p
Matte black
Industrial spray glue i swear i did'nt just sneeze
As i went to print the designs this is what i got
Don't do this to me lexmark!!
Finished designs
Photoshop Wizards design stuck down after being laminated
Final pictures to come with the monitor when i borrow my brothers Nikon D90!
Thanks for watching
DeadP1xels
« Reply #19 on: June 01, 2010, 12:44:35 PM »
Some final pics went ahead and used my dads s200hd will be taking some more possibly later as these don't really do it for me
Check out the video and subscribe to my channel for future mods :)
http://www.youtube.com/watch?v=0ytPETVQswc
« Last Edit: June 01, 2010, 12:47:37 PM by DeadP1xels »
Page created in 0.479 seconds with 33 queries.
