  • February 16, 2019, 11:32:49 AM
Author Topic: need more storage  (Read 7424 times)
need more storage
« on: December 17, 2009, 06:20:15 PM »
is it possible to hack a device with microsd storage to use another type of storage (say regular sd or some other flash memory type)? 16gb isn't enough storage :(
i would imagine that since a regular sd card adaptor can read a micro sd card, in theory the reverse would be possible if i knew the pinouts
bliq
Re: need more storage
« Reply #1 on: December 17, 2009, 07:57:58 PM »
Do you mean you want make something external to the device that can hold say, an SD card or something?  I don't doubt it's possible to extend a mSD card to a ribbon cable that ends in a USB port that you can plug anything into- but I don't think it would be very sturdy.  You need some good, fine soldering skills- and if you're going to mess up a perfectly good mSD card- go sell your 16GB one and buy a 256MB one and cut that up.
« Reply #2 on: December 18, 2009, 09:11:28 AM »
maybe this would help:
http://www.camerahacker.com/Digital/Inside_miniSD_Adapter.shtml
It seems like it's just a clean passthrough, take away an unused pin here or there.
« Reply #3 on: December 18, 2009, 02:28:44 PM »
Yeah, a ribbon cable kind of setup is what I was hoping for. On my phone I could pass it underneath the battery cover and attach a full sized SD card or whatever to the outside of the battery cover, and then cover it with something else to make it look nice.
I have a 256mb SD card lying around unused (it came with an old phone) so I may try a ribbon cable from one card holder to another and see if it works. It shouldn't fry a motherboard's USB ports or anything right?
KoRn Addict
  • It's not METAL enough!
« Reply #4 on: December 21, 2009, 12:18:58 AM »
On a related note, the DROID is stated to have a max microSD capacity of 32gb; possible to exceed with an SD card?
snow veil
« Reply #5 on: December 25, 2009, 10:03:04 PM »
Unlikely unless the firmware is updated to support capacities higher than 32GB.  SDHC is limited to 32GB as well, "SDXC" is going to utilize a newer filesystem to support 64GB and above.
« Reply #6 on: December 27, 2009, 01:02:33 AM »
it's just linux, i think it really shouldnt be hard to update the filesystem / max storage / partition
KoRn Addict
« Reply #7 on: December 30, 2009, 02:55:27 PM »
Sadly, it's only based on Linux, and I am uncertain that firmwarez will be updated. Now rooting the phone might yield a different story...
Page created in 0.051 seconds with 20 queries.
