Update: The design of the front!
In recent days I have been doing the front, is not so much that remains there now, so hope to be finished during the week.
Have hidden fan control and made a hole on the tray on the DVD burner. Power button is also in place:)
Marking the power button:
Used a 20mm borr:
Pre-assembled:
Fan Control, I have hidden in the front, so that only the buttons appear. Did a little test first to see how it was:
In place of the faceplate:
Regretted a bit that I cut out the hole to 5 1 / 4 "bayen in front, then took the team to a record as I plugged the hole with:
There, I have now made a hole to the DVD tray and mounted the fan control:
Gets a little filler and sanding around the new disc, to get a good result:
Have also been installed in 5 DVD burners 1 / 4 "bayen:
In addition, to this I have lowered the one grill a little down in the plate:
The result so far:
There are a few more updater throughout the week, so just go with:)
