  • August 11, 2020, 01:49:07 AM
Author Topic: Thermal Paste Removal  (Read 3440 times)
keristillax
« on: August 06, 2009, 09:52:17 PM »
Ive got a CPU with some baked on paste, came out of a gateway. Alcohol doesnt even touch it, I was thinking to try a more concentrated form of it. I know I can torch it off the heatsink but any suggestions on the die? I dont want to use acetone or laquer thinner, paint stripper before I know I actually can use it. Any suggestions? This stuff is FULLY CURED.
Re: Thermal Paste Removal
« Reply #1 on: August 06, 2009, 10:34:36 PM »
Acetone free nail polish remover has worked for me in the past.
pinkpanther
« Reply #2 on: August 07, 2009, 09:23:12 AM »
Goo Gone followed by a good swabbing of 99% rubbing alcohol.
ClearCaseMan
    • http://www.casemodman.com
« Reply #3 on: October 17, 2009, 06:26:01 PM »
The best hands down solution to your problem.
http://www.gideontech.com/content/articles/282/1
newb_of_2005
« Reply #4 on: October 18, 2009, 04:17:08 PM »
I second the arctic silver stuff.  Works amazingly.
Page created in 0.085 seconds with 33 queries.
