  • September 29, 2020, 12:15:58 AM
Author Topic: HDTV quality good enough to use a pc monitor?  (Read 10833 times)
Re: HDTV quality good enough to use a pc monitor?
« Reply #10 on: June 09, 2009, 11:27:11 AM »
DVI to HDMI is a straight conversion (except DVI doesn't have sound) so as long as the TV has HDMI inputs then you are ok.
Glitch
« Reply #11 on: June 09, 2009, 11:57:56 AM »
Thanks I'll just go HDMI with the adapter that came with the card
E8400 w/ Freezer pro 7
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
YucA
« Reply #12 on: June 10, 2009, 03:33:55 PM »
RIGHT!
And what you asked about the difference with digital vs analog...  From what I've seen, on larger screens you can tell the difference a bit more when compared to a monitor (>20").  Colors are a bit richer, and less "off sync" when rocking digital.
Page created in 0.329 seconds with 34 queries.
