  • March 02, 2021, 05:57:50 PM
Pages: 1 2 3 [4] 5   Go Down
Author Topic: Project:PURE "FINISHED"  (Read 37551 times)
mnpctech
    • http://www.mnpctech.com
Re: Project:PURE
« Reply #30 on: August 01, 2009, 06:28:10 AM »
This is one clean build. excellent job!
Re: Project:PURE
« Reply #31 on: August 01, 2009, 12:06:29 PM »
I love this.  You've done an increadible job so far.  I wish I had the funds and motivation to do another H2o rig.  Keep up the good work!
                              Brian
subset7
Re: Project:PURE
« Reply #32 on: August 02, 2009, 03:02:19 PM »
Thanks Bill,looks cleaner now with your awesome fan grills  :D
                              Brian
Thanks Brian,I had hoped to get all the wiring finished this weekend but I had to go in to work so i've done nothing  :(
« Last Edit: August 02, 2009, 03:03:51 PM by subset7 »
mnpctech
Re: Project:PURE
« Reply #33 on: August 20, 2009, 09:10:42 AM »
Cool, look forward to the next update subset  :thumbsup:
subset7
Re: Project:PURE
« Reply #34 on: September 03, 2009, 12:05:13 PM »
Been a while since I last updated this as I haven't had much time lately,anyway I sleeved the power/reset switches individually
Fitted back in the case
I got two of these displays to monitor the water temperature in the two res's
These are going in to one of the 5.25" bay covers which i've marked out
And after a few cuts with the Dremel
Before the displays go in I wanted to spray them white,which means dismantling them,to do this you need to cut the retaining slots on one side
Cut out with a sharp knife
Tha back should just pop open then
Tha PCB removed
Now i'm left with the piece I want to paint
Sprayed and clear coated
Test fitted in the cover
Just need to reassemble them now,I hope to get this finished at the weekend that's if the missus doesn't get on my case about doing the garden,it's starting to get a bit wild out there :)
subset7
Re: Project:PURE
« Reply #35 on: September 04, 2009, 03:19:49 PM »
I've reassembled the displays and done a quick test just to make sure they were ok
Everything seems fine so i'll solder them up to the sensors in the res's tomorrow.
Re: Project:PURE
« Reply #36 on: September 04, 2009, 05:03:48 PM »
nice temps  :thumbsup:
Re: Project:PURE
« Reply #37 on: September 05, 2009, 07:19:40 AM »
Looking good.  Where did you get those temp display's?
mnpctech
Re: Project:PURE
« Reply #38 on: September 06, 2009, 09:45:12 AM »
Nice work subset!
subset7
Re: Project:PURE
« Reply #39 on: September 06, 2009, 12:34:41 PM »
Thanks urgannagru  :)
Thanks wonko,I got the displays from Here
Nice work subset!
Thanks Bill  :)
Well this is finished now apart from the lighting,I need a couple of extensions for the CCFL's,so I wont post the final pics untill I get them fitted,but here's a couple of pics of the front with the displays in
Final pics to follow soon
Pages: 1 2 3 [4] 5   Go Up
Page created in 0.11 seconds with 33 queries.
