  • July 05, 2020, 09:44:25 AM
Pages: 1 [2] 3 4 5   Go Down
Author Topic: Project:PURE "FINISHED"  (Read 34290 times)
Glitch
Re: Project:PURE
« Reply #10 on: June 14, 2009, 07:56:26 PM »
WOW just wow  :)
E8400 w/ Freezer pro 7
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
subset7
Re: Project:PURE
« Reply #11 on: June 19, 2009, 10:11:13 AM »
Thanks for the comments  :thumbsup: just a small update with the DVD drive
Stripped down and primed
Sprayed satin black and reassembled
That's all i've got for now untill I do the braiding.
subset7
Re: Project:PURE
« Reply #12 on: June 21, 2009, 11:57:23 AM »
Here's a couple of pics of the PSU before braiding
In keeping with the black and white theme
24 pin plug removed
Murder Mod psycho pack braid
Got to love the personal touch
I'll post pics of the 24 pin braided tomorrow :)
subset7
Re: Project:PURE
« Reply #13 on: June 23, 2009, 05:07:34 PM »
I've got all the hardwired cables done now,I need to move the plugs on the SATA power cable before I can finish the modular cables,I had hoped to take the braiding right in to the PSU but as you can see it's so tight in there with those heatsinks there just wasn't the space for that volume of braid,so I had to just heatshrink the ends of the bundles,even then it was a struggle to get the cover back on
With the cover back on
8pin Pci-e
24pin
All of them together
PSU fitted in case
And plugged in
Just need to even them out a bit now.
Glitch
Re: Project:PURE
« Reply #14 on: June 24, 2009, 07:39:20 PM »
Never seen individual wire sleeving like that done on a psu :thumbsup:... seems time consuming, I could never pull that off  :lol:. Btw what's the doodle about?
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
subset7
Re: Project:PURE
« Reply #15 on: June 26, 2009, 02:55:03 PM »
It's Nils from Murdermod,I think he just likes drawing :),Just a small update,I got the HDD's and DVD drive fitted,here's the HDD's
They're going in the two 5.25" bays below the res's so i'm using these mounts
Here they are fitted
And fitted in the case
I moved the plugs on the SATA power and sleeved that aswell
Plugged in
That's all I've got for now,untill next time :)
Glitch
Re: Project:PURE
« Reply #16 on: June 26, 2009, 08:26:52 PM »
Maybe it's just me but the sata power plug on the first hdd looks to be under some stress.  :o maybe a lil too much tension, that doesn't look too good for data quality and the fight against corruption  :lol:
Ga p35 ds3l
Seagate 250GB HDD
Seagate 320GB HDD
subset7
Re: Project:PURE
« Reply #17 on: June 27, 2009, 06:18:45 AM »
Well spotted,you're right it was under some tension,i've adjusted the wires and it's fine now :)
Re: Project:PURE
« Reply #18 on: June 27, 2009, 11:34:55 AM »
How come you're fitting the HDs with coolers?  Just to make them fit in a 5.25 bay, or are you providing minimal cooling outside the WC setup.  The HD103UJ seems to run pretty cool (like 8C cooler than the Seagate 7200.10 it replaced)
Re: Project:PURE
« Reply #19 on: June 27, 2009, 12:55:29 PM »
Well it doesn't seem like he really had a choice.  There wasn't much in the way of 3.5" bays in his case.
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.067 seconds with 33 queries.
