  • August 21, 2019, 08:07:52 PM
Author Topic: Winamp plugins  (Read 2625 times)
divideByZero
  • woof
Winamp plugins
« on: May 31, 2009, 09:38:06 AM »
Has anyone had any experiance with winamp plugins? I need to create something that can send now playing info in raw ascii via rs232. I have the sending part figured out but I dont know how to work with winamp. their documentation is really iffy for the sdk.
Re: Winamp plugins
« Reply #1 on: May 31, 2009, 10:37:54 AM »
While I have no experience with making Winamp plugins, I just wanted to say that I abandoned Winamp long ago due to sketchy Vista support, constant crashes, advertisements, and more. I now use Songbird, which is open source, cross platform, and has plugin and skin support. Since its open source and developer friendly, you may want to give it a try.
http://getsongbird.com
Alternately, you may want to try Amarok http://amarok.kde.org/ (also open source, cross platform, and can use scripts)
« Last Edit: May 31, 2009, 10:53:23 AM by urgannagru »
divideByZero
  • woof
Re: Winamp plugins
« Reply #2 on: May 31, 2009, 12:50:07 PM »
neat, ill have to give that a try. I was a little apprehensive about using winamp, i stopped using it long ago b/c it was dodgy but it was the first thing i thought of when thinking about plugins.
bliq
Re: Winamp plugins
« Reply #3 on: June 02, 2009, 03:12:06 PM »
That said, winamp probably still has a bigger audience than Songbird or Amarok so if you're creating a plugin for public consumption, you might want to get a winamp plugin made still.  if it's just for you, then no problems.
Ronin
  • GURNING ALL WAY HOME.
Re: Winamp plugins
« Reply #4 on: July 17, 2009, 10:29:50 AM »
I'm still looking for something that will work as nice as R4...
http://www.rabidhamster.org/R4/main.php
Iv3 b33n H4x0r5.
Page created in 0.053 seconds with 19 queries.
